Question about Konica Minolta Bizhub C451 Printer/scanner/finisher
Paper get stack in the midle of printer before gets into the fuser
    Problem Solver:
  • 7 Answers
Check the specs and make sure the paper is the appropriate weight (I have found 70 gsm doesn't work in mine as too light). Fan the sheets before inserting them in the cassette or paper tray. Clean the paper path by vacuuming the inside, maybe holding the printer and shaking it so any paper dust falls out. Good luck.
Posted on Jan 01, 2014
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
My printer stoped in the midle of print
The 2280+ is indicating a defect with the paper width sensor, the paper width sensor on the 2280+ is locate on the carriage and detects when you try to print off the paper.
You may wish to disable the paper width sensor. To continue printing, this can be done in the following way.
Power the printer on holding down ONLINE
When the printer displays ASCII80 ASCII136 along the top line of the display release the ONLINE button.
Press the Button under NEXT (button 4) repeatedly until you see APW
Press the button under APW
Press button 3 to change this to OFF
Press SET
Place the printer ONLINE to exit the menu.
This will disable the Paper Width sensor which should resolve the issue with the message being seen. You can then get an engineer to look at the paper width sensor to see why this is not working.
Aug 05, 2009 | TallyGenicom 2280 Matrix Printer
Toner overflow
Could be the cleaning blade isn't working on the drum.  Is the paper getting stuck on the fuser unit?
Oct 25, 2008 | Ricoh FT3713 Copier
Constant Paper Jam1
It sounds as though you need a new fuser assembly. Not too expensive and worth having repaired. You should contact a technician in your area.
Jul 24, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Paper stack
If paper stops just before entering the fuser (heat rollers), chances are they are not turning. You may have a broken gear or a drive clutch that is slipping badly. Usually those clutches need to be replaced by a technician.
May 21, 2008 | Canon NP 6050 Copier
PAPER CREASES AS IT EXITS THE PRINTER
No you will have to get a techie out - the plastic gears is not aligned - seems to be due to wear and tear. (this shoud be re-fastened or replaced. (not an expensive exercise)
Apr 19, 2008 | Xerox DocuColor 12 Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
Paper jam
If the jammed sheet is entirely within the printer, remove the sheet as follows:
r_1.gif Make sure that the printer is turned off.
r_2.gif Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
hppe004.gif 1. CAUTION Hot Surface Avoid Contact
r_3.gif Remove the developer cartridge.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
r_4.gif Remove the photoconductor unit.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
r_5.gif Remove the paper from the paper path.
r_space.gif r_note.gif Note: r_space.gif r_space.gif If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
r_6.gif Reinstall the photoconductor unit, and then the developer cartridge.
r_7.gif Close the printer cover.
r_8.gif Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
Oct 16, 2007 | Lexmark X7170 All-In-One InkJet Printer
Konica Minolta Bizhub C451 Printer/scanner/finisher Logo
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
