Question about Nintendo Wii Console
I set up my wii to my tv. it was working for a few minutes and now it says unsupported mode. why?
Go to best buy
Posted on Jan 01, 2014
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I was trying to get on my Wii, and I keep getting UNSUPPORTED MODE. What does this mean and how do I correct it? Billy
Hi cychiszj,
Try enabling your Interlace mode ( please note that although most games support Interlace mode, not every game has this support- hopefully yours is supported ) Go to the Operations Manual in the game Press Z +A+2 to enable Interlace mode. To deactivate, just press Z+A+1. This should solve the problem. All the best to you. Good luck.
Jul 22, 2011 | Nintendo Wii Console
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
How do i set componet 2 to hdtv on a samsung HLN617W, it says unsuppoted mode
When you get an Unsupported mode error on this tv, its usually not the tv. Change the resolution on the source to something the tv can handle.
Sometimes samsung labels the component ports in the back of the set so you know what it can accept.
Dec 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Nintendo wii power problem
Unplug the power cable from the wall and the wii for 5 minutes so it can reset. It must be removed from the wii and the wall.
Jul 06, 2008 | Nintendo Wii Console
Wii code:51330
boussole,
There are a few things you can try to fix this error code (51330):
  1. Set your router to Mixed Mode. It won't work on G-only mode.
  2. Set the channel on your router to either 1 or 11.
Let me know if this helps. Good luck!
Feb 09, 2008 | Dell Wireless 2350 Router
Screen splits into 2 vertical images when connecting Wii Component
if you have a user manual find the word settings, then look for the word NTSC/PAL. mybe you can change your mode which is compatible to your TV set. one more suggestion, set your Tv set in auto mode in Video.
Dec 19, 2007 | JVC AV-32D305 32" TV
Restore factory settings
To reset back to the 50 Mhz frequency on a Wii you press reset on the Wii and the down direction button/rocker on the wii remote. It works - I just did it!
Nov 27, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
