Question about Aiptek PenCam Trio II Digital Camera
CD download and manual download and driver download
Can I get all the downloads in one download for windows xp
My system now window7 .iwant instaling window xp .but no awaiable boot iwant driver
You can download the latest version (sp3 2011) of windows xp from this link:
http://www.world4free.in/2011/02/windows-xp-sp3-2011-v-1102-full.html
After downloading, place a plane CD in the CD/DVD writer and then double click the downloaded file. Now the burning process will begin. After burning is successfully completed, you can use this CD as your boot disc. Follow the installation procedure as usual.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Acer INTEL CELERON DUAL-CORE PROCESSOR...
Show to install sound device driver in windows xp ?
  • 1 Insert your driver disk into the CD/DVD ROM drive. The disk should automatically boot. Then follow the on-screen instructions. This usually entails clicking on "Install" or "Install Sound Driver."
  • 2 Download the sound driver specific to your card and Windows XP. Driver websites include Drivers Kit, XP-Drivers and Driver XP. Locate the make and model of your card. Click on the manufacturer and then select the "Download" link.
  • 3 Double-click on the sound driver. The application will go through a setup process. Follow the on-screen instructions.
  • Manual Installation
  • 1 Click on the "Start" menu. Select "Control Panel," then scroll to "Add Hardware" and click to open. Sometimes, the automatic installation does not work properly. You will then need to install the sound drivers manually.
  • 2 Read and use the "Add Hardware Wizard." Click the "Next" tab. Windows XP will scan your computer for components.
  • 3 Scroll down the list to "Audio Drivers" or "Sound Drivers." Then click "Next." Select the "Finish" tab. Another window will appear.
  • 4 Select the "No, Not This Time" option on the "Hardware Update Wizard." Click "Next." Choose the "Install from a List or Specific Location" button. Then click the "Next" tab again.
  • 5 Place the sound driver disk in the CD/DVD ROM. Point the "Search Option" to your CD/DVD ROM or download folder. Click the "Include This Location to Search" box. Type in the path to your download folder or select the "Browse" option. Search through the computer to choose your download application. Click "Next."
  • 6 Wait until the file installs. This takes approximately two to three minutes. Turn up your speakers and reboot your computer
  • please rate my service with 4 thumbs up
    Nov 23, 2010 | Computers & Internet
    Canon Ixus 960 IS Driver Problem
    Hello :
    This link contains the right driver for your CANON DIGITAL IXUS 960 IS .
    PLEASE DON'T FORGET TO RATE !
    GOOD LUCK .
    Apr 08, 2010 | Canon IXUS 960 IS Digital Camera
    Driver ?
    Here's an easy way to download and install / update your SONY CD/DVD writer drivers:
    Use this driver scanning tool, which scans your computer for the needed drivers. It has an option to automatically retrieve the drivers for you.
    You can download this free driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.cfm (copy/paste the link, if you can't click it).
    After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
    For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
    Hope that helps,
    Regards,
    Raspal
    Mar 22, 2010 | Sony Computers & Internet
    775i65g Drivers for windows 7? please help
    windows 7 will use the xp or vista drivers.
    you may need to install it manually
    1.) click start
    2.) right click computer
    3.) click properties
    4.) click device manager
    5.) make sure your driver cd is in the cd drive
    6.) right click any device with a yellow marker and select update driver
    7.) follow the on screeb instructions for windows 7 to browse and install the drivers for you.
    If you have an internet connection run windows update
    the drivers will be in the updates.
    if you have to download the drivers then u will need to unzip it to a folder and specifiy that folder when you choose to update your device. (6.7 above)
    drivers can be downloaded from the manufactures web site for your device.
    Feb 26, 2010 | Asrock 775i65G Motherboard
    Can't find disc
    I suggest emailing lexmark and telling them u need a disc for a Lexmark X2550 printer. Maybe tell em yours didnt come with one when u bought it and be firm...or you can continue to try and download it from the internet.
    Aug 23, 2009 | Lexmark X2550 All-In-One Printer
    Dell Resource CD - not working in Windows XP SP3 version
    You are using the Dell Resource CD provided by the manufacturer. This CD may not work with new versions of Internet Explorer that come with SP3 installations (if you reinstalled from a Windows XP CD not provided by Dell or if you did the Microsoft SP3 update).
    You're only solution would be to use your "Service Tag" number underneath, for laptops (or on the back/side for Desktops), of your computer and go to http://support.dell.com to download the drivers for your specific system. If this computer doesn't have the drivers for you to be able to go to the internet, use a second computer and go to the site. Then download the individual drivers listed (the latest dated drivers will work best).
    Once you've downloaded mainly the Video, Network, Audio drivers, use a USB Flash drive (sometimes called USB Key, USB pen drive, USB drive, etc) and copy what's been downloaded onto it. Do not double click on the files while they're on the second computer.
    Once on the machine with Windows XP SP3, double click on each downloaded file (1 at a time) and follow the on-screen insctructions to install the driver. You should be fine afterwards. :) Let us know how it goes, and rate us. :)
    Jul 19, 2009 | Dell ResourceCD (2p730)
    Driver download
    download scnner 5600/5650 driver
    Oct 09, 2008 | Umax Astra 6400 Flatbed Scanner
    Genius Model:Video CAM NB
    Hi
    Genius VideoCAM NB -
    Windows XP, 2K, 9X Drivers - http://download.geniusnet.com/CAMERA/webnb.zip
    Try same drivers for Windows Vista
    User's Manual - http://download.geniusnet.com/manual/webcam/NB-ENG.PDF
    Regards
    Mike
    Mar 23, 2008 | Computers & Internet
    Aiptek PenCam Trio II Digital Camera Logo
    29 people viewed this question
    Top Aiptek Cameras Experts
    mohamed salim shaikh
    Greg Cann
    Greg Cann
    Are you an Aiptek Camera Expert? Answer questions, earn points and help others
