Blinking envelope appears on screen when I turn on my mac.
My Mac was fozen, I turned it off and when I attempted to turn it back on a blinking envelope appears on the screen. I cannot find my boot disks. Is there a work around?
bizzyb0t
  • 26 Answers
SOURCE: My Mac wont work. blinking Folder with "?"
Another alternative is to hold the "option" key as the Mac boots up to force it to recheck possible blessed start-up disks. If your hard disk drive shows up, select it. When it boots into OS X, immediately back up your data and restart the Mac with the OS X DVD (or CD) Install Disk. When you're in the boot menu from the OS X Install Disk, select "Utilities" then "Repair drive" and select your HDD. That should help OS X repair any file permissions or data corruption that may have occurred. I would also look into getting a new HDD. It seems to me that your current one may be failing and need replacement.
Posted on Jan 18, 2008
enov8
  • 53 Answers
SOURCE: Question Mark folder in my mac notebook
hey if you have the Utilities disk or any Mac OS install disk, place that in the computer, restart and hold down the c key.
That prompts the computer to boot from the cd.  If it gets past the question mark folder, then we are making progress.
At this point exit out of the installer, (unless you want to do a new install)  look through the top menus, to find the utilities options that will allow you to run a diagnostic and repair.  That should get you on the right path.
Let me know if this gets you back up again.
I do have some other steps that may also work if the problem persist.
Have a great one!
enov8  = )
Posted on Mar 06, 2009
robert654
SOURCE: mac book will not turn on.
http://www.ifixit.com/Guide try this location for a guide
re-set your pmu 1. disconnect battery and power supply 2. hold down start button for 5-6 seconds 3. re-connect battery and power supply try to start if nothing might be your dc-in board/ has failed good luck
Posted on Apr 01, 2009
APPLESUPPORT
  • 70 Answers
SOURCE: Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Posted on Apr 20, 2010
SOURCE: Blinking Envelope on stanby screen
Firstly save any data you want to keep.For a full factory reset type 2945 hash star hash ,sorry my hash sign isn't working on the keyboard.
If sim locked to unlock 2945hash star 71001 hash 3
This solved my annoying blinking envelope.
Posted on Jul 17, 2010
My macbook air start to show me a white screen white a blinking folder inside
Sound like you have an issue with either your hard drive or the operating system has lost the plot. Try this OS About OS Recovery
If you are able to access the recovery partition then use the disk utility to check the disk.
If this does not work then take the computer to an Apple repair centre, if it's still covered by warranty the disk might be replaced under warranty.
If it's not covered, you could try using DiskWarrior 4 The Disk Utility for Mac Disk Repair Mac Directory Repair... which has allowed me to recover disks that have not been able to be repaired with Apple's disk utility.
Dec 28, 2013 | Apple MacBook Air
Denon x600 want go to mac
Wrong... there are setting on the mixer that will get u on track..make sure you un plug usb FROM mixer. Turn off I'm not 100% sure ether master effect insert I know it is 1 of the insert buttons wit the right 1 hold down button turn the knob closet effect screen if right that screen should turn from PC 2 MAC when you see this hit the left BEAT BUTTON to save setting
Aug 31, 2012 | Denon DN-X600 DJ MIXER
Hi there,I have a 05 mac lap top.This am I turned it on and it appeared fine.Then i went to close it and must have pushed a button.Now the screen is blank and is showing a blinking folder with a question...
It sounds like the system is corrupted. What I would do is to get your instal disk to boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Mar 27, 2010 | Apple MacBook Mac Notebook
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Computer and monitor will not turn. blinking power light 3x
This is just an off-chance thing. The three lights could indicate a failed or badly seated memory chip.
Turn the Mac off and remove the side. Remove the perspex panel and then remove the grey plastic panel containing the 2 large fans (it just pulls out towards you).
You now have access to the RAM sticks. Use the illustrations on the inside of the Aluminium door to identify the sticks and so that you can remove and re-seat them. Refit the fans and the perspex panel and see if the mac will start up. If not, you may have to try extra RAM (depending on how much you have installed). These macs have their RAM installed in matching pairs so if you have only 2 stick in your Mac then you need to get 2 more in order to eliminate the first 2.
Report back if that helps.
Oct 11, 2009 | Apple Power Mac G5 Desktop
Blinking question mark on screen
Either the video card is not updated with the newest drivers, or the monitor is set to a refresh setting or other setting that your pc can't handle.
Aug 05, 2009 | Apple 13 MacBook Notebook Computer ...
Pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Jul 13, 2009 | Radio Communications
My mac wont work. Blinking folder with a ?
sounds like like your hardrive has died or you have lost your operating system use the recovery disc that came with your computer to reload the computer as it was from the factory.
IF this doesnt work replace your harddrive
Jan 17, 2008 | Apple MacBook PC Notebook
Computers & Internet Logo
David Payne
David Payne
