Question about NAD T752 Receiver
How to turn on nad t-752 without remote - NAD T752 Receiver
I need the Dish Network code for the Remote for Broksonic CTGV-5463GVC 19" TV. None of the codes in their book work.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. Each of our different models of remotes have a few different codes that could work. I will list here for you the best codes for the more popular models of remotes that we have and the instructions for addressing the remote to the TV. I hope this information helps and if you have any further questions please let me know!
Remote Model #'s Codes for TV
3.0, 3.1, 3.2, 3.4 IR remotes - codes 720, 748, 752, 661.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 720, 748, 752, 656.
4.0 and 4.4 IR/UHF remotes - codes 720, 748, 752, 721, 656.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 720, 748, 752, 533, 656.
20.0 IR and 21.0 IR/UHF remotes - codes 834, 899, 750, 748, 533, 622, 754.
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the mode lights light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 27, 2011 | Broksonic CTVG-5463GVC 19" TV
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
Tip
Dish Network Stereo Receiver Remote Codes
This is the From the Dish Network website. http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml You can also call them for information on your set-up at : New customers call: 1.888.825.2557. Current customers call: 1-888-686-2388. CODE Aiwa Amplifiers 636, 641, 656, 687, 718, 720, 774, 775, 726 Bose Amplifiers 761 Carver Amplifiers 653 Citizen Amplifiers 709 Curtis Mathes Amplifiers 734 Denon Amplifiers 647, 674, 757, 758, 759, 760, 762 Fisher Amplifiers 653, 741 GE Amplifiers 711 Goldstar Amplifiers 677, 69 Harmon / Kardon Amplifiers 640, 672, 751 Hitachi Amplifiers 717, 754 JBL Amplifiers 640 JVC Amplifiers 637, 683, 703, 725 Kenwood Amplifiers 649, 676, 691, 726, 728, 745 Luxman Amplifiers 752 Magnavox Amplifiers 654, 705, 740 Marantz Amplifiers 651, 740, 742, 743, 764 NAD Amplifiers 739 Nakamichi Amplifiers 671, 748, 750 NEC Amplifiers 716, 739 Onkyo Amplifiers 642, 660, 662, 678 Optimus Amplifiers 648, 664, 734, 744, 749 Panasonic Amplifiers 643, 644, 652, 742, 746 Pioneer Amplifiers 658, 667, 668, 679, 702, 734 Proton Amplifiers 654, 705 Quasar Amplifiers 652, 742, 746 Radio Shack Amplifiers 744 RCA Amplifiers 635, 638, 704, 727 Sansui Amplifiers 753 Sanyo Amplifiers 741 Sharp Amplifiers 712, 713, 714, 715, 749 Sherwood Amplifiers 646, 670, 736, 738, 744 Sony Amplifiers 639, 645, 650, 687, 728, 728, 730 Soundmatters Amplifiers 763 Teac Amplifiers 684, 737 Technics Amplifiers 643, 644, 652, 742, 746 Toshiba Amplifiers 710 Yamaha Amplifiers 663, 730, 731, 732, 733, 745, 747
on Jun 06, 2009 | Toshiba XB1507 Receiver
Powers on in standby mode but shuts off when anything is pressed remote or manually? t-752 reciever
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 05, 2011 | NAD T752 Receiver
Hi Need to change NAD T515 to region free/ Thanks
Same procedure as NAD T514
1. Turn player on without any disc in.
2. Push "pause".
3. Push "3, 1, 4, 1, 5, 9".
4. A blue menu comes visible. Follow instructions there, or turn "0" and "pause".
5. Turn of player.
Mar 04, 2011 | NAD T 515 DVD Player
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Dec 27, 2007 | NAD T743 Receiver
Nad 752
i would suspect a missing supply or speaker protect relay shorted? or staying closed too long. I'm not familiar with this model but a common failure is bad connections. Inspect all heat sinked parts and small value resisters used as fuses. Look for cracked solder joints on all parts, tighten pcb grounding screws. Memory is most likely powered by a high value cap or stack cap that maybe bad. Or the diode used to charge during usage maybe leaky , other part in ckt leaky, or the memory device itself is drawing excessive current off the memory cap. I have seen small 0.1uf disk caps turn into 1k resistors.
Nov 05, 2007 | NAD T752 Receiver
NAD 7100 How to turn off low level without a remote
You can ONLY defeat this feature by modifying the circuit on the mother board. The remote availability has nothing to do with this feature on power on
Sep 25, 2007 | JVC RX-6008V Receiver
Nad 712 output issues - Mute flashing
The only thing I can tell you for sure is that the mute indicator always flashes (very dimly) when the receiver is off.  I have no idea why, but mine has always done this.
Jan 23, 2007 | NAD 712
NAD T752 Receiver Logo
67 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
