Question about VinoTemp VT-18TEDS 18-Bottle Thermoelectric Wine Cooler
Vt28teds-t wine cooler doesn't work. Don't know its history. Plugged it in, no fan, no light, no temp readout. Not dusty, cord in good shape, no apparent leakage. It's been sitting awhile, should I wa
Don't know its history. Plugged it in, no fan, no light, no temp readout. Not dusty, cord in good shape, no apparent leakage. It's been sitting awhile, should I wait 24 hrs and try again? Help
3 Suggested Answers
  • 14 Answers
SOURCE: VinoTemp VT28TEDS - circuit board
Here is the phone number for Vinotemp International 800-777-8466 for customer service.
Posted on Sep 21, 2009
bobicehouse
  • 1524 Answers
SOURCE: My Vinotemp VT52SN stopped cooling.
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Posted on Jul 08, 2011
Vinotemp 28teds doesn't work, no fan, temp or light, what's up
Probably somewhere in its history there was an incident of total failure.
Dec 31, 2013 | VinoTemp 28Bottle FreeStanding Wine Cellar...
Will not cool, heats to 4 degrees above room temperature
I HEAR BAD THINGS ABOUT THESE.. TRY DEFROSTING IT, USE A FAN TO SPEED UP THIS PROCESS , REMOVE ALL THE FOOD STUFFS AND DOOR OPEN LET THE FAN BLOW FOR ABOUT A HOUR , IF YOU GET A BUNCH OF WATER OUT IT. THIS WAS THE PROBLEM ..GOOD LUCK AN VOTE IF I WAS OF HELP.. YOU KNOW I DO THIS 4 FREE RIGHT ?
Sep 10, 2011 | VinoTemp 28Bottle FreeStanding Wine Cellar...
I Have a Magic Chef MCWC44DZ and it is reading 82 for both zones. When i try to set it back to the normal temps it just locks up and goes back to 82
try to reset your unit unplug it then after a several minutes plug it on then observe unit. check your condensing unit the fan motor if working smoothly or clean your condenser possible dusty. use pressurized water. adjust your thermostat setting.then observe it.
Mar 10, 2011 | Magic Chef MCWC44DZ Wine Cooler
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
VinoTemp VT-18TEDS 18-Bottle Thermoelectric Wine Cooler Logo
18 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
