Question about Craftsman 5600 watt Generator
Wont supply 220 volts was fine now puts out 110 only only has 25 hrs on it !!!!
Requires 220v, can it be converted to 110v?
NO
if the plate states 220 volts ten it has be constructed to run 220 volts
if you powr supply is 110 volts you may be able to get an inverter that will boost that power supply to 220-240 volts
Mar 31, 2016 | Bosch TASSIMO Coffee Makers & Espresso...
My GE PGS975 DEP1 (GAS RANGE) DIGITAL CONTROLS ARE NOT WORKING. I purchased this brand new gas range in the USA and had it shipped to Brazil. After i installed it and plugged it on every think worked...
Power supply in Brazil is not universal over the entire country. Your range was built for 120 volt, 60 Hertz power supply. If you are in some areas, you may not have the proper voltage available. 127 V found in states of Bahia, Paran? (including Curitiba), Rio de Janeiro, S?o Paulo and Minas Gerais (though 220 V may be found in some hotels). Other areas are 220 V only, with the exception of Fortaleza (240 V).
Brazil does use 60 Hetz, but if you are in an area which only supplies 220 or 240 volts, you would need some type of adapter to convert that to 120 volts for your gas range. If you connected to the higher voltage, you may have irreversably damaged the electronic control, requiring control replacement, before connecting to the proper (120 volt) supply. I would expect 127 volts to operate your range, but if the voltage varied up from that, it could damage the control. Even in the US, voltage variations of 108 to 125 are rather common.
May 22, 2011 | General Electric Profile PGS908 Range
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
QUINTON CLUB TRACTURNED MACHINE ON..THOUGHT IT WAS 220 VOLTS..SAW
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
Jan 29, 2010 | Exercise & Fitness
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
Craftsman 5600 watt Generator Logo
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
