Question about Bose in-ear headphones - Black with black/white cord
Frayed wires on bose ie2
How to take the speakers apart
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: do I need special speaker wires to hook up bose
It comes with special connectors - not necessarily special wire.
You will need the Lifestyle Cables.
c35cb24.jpg Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 01, 2009
SOURCE: Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Posted on Nov 14, 2009
Reconnecting/retiring Bose speaker cones. Inside speaker I have four coloured wires....Red,Black, Green & Orange....which connectors do they attach to on the speaker cone?
Since you posted this in cars and trucks I assume this is a bose car system. Most bose auto systems have the amp physically attached to the individual speakers. This means each speaker needs the following wires +12v, 12v ground, + signal and - signal. It also means that the head unit cannot directly drive a non bose speaker. If you are replacing the speakers and bose radio the best thing to do is to run new speaker wires. You can reuse the factory ones if you can identify which ones are what...and that may be a pain. If the bose amps are ok and you want to replace the speaker you would need to leave them connected and wire the new speaker to the wires on the bose speaker that come from the bose amp. Depending on the specific bose system there may be an actual wire that runs to the speaker from the amp but on others the amp is directly connected to the voice coil leads of the bose speaker.
Oct 13, 2016 | Cars & Trucks
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
The left speaker of my Bose On-Ear headphones suddenly stopped working although putting pressure on it makes sound come out for a very short time.
This may sound strange, but try slipping a piece of cotton on the area where the bare conductor runs through the plastic covering of the speaker (as suggested here). 39c682c9-7c92-4e14-963e-7b6eb35c074d.jpg
Apr 04, 2011 | Bose Audio Players & Recorders
I have a Samsung HT-510 Center Speaker that has no sound. I was going to take it apart to see if there may be something loose inside. I took the 12 screws out of the back, but still cannot seem to get...
It takes a bit of force, but be careful. the back terminals are connected to the speakers by rather short lengths of wire. The other probable causes are that:
The amplifier's center channel has failed
The wire is shorted or frayed, or defected in some other way.
The speakers are broken. If this is the case, any speaker of 170 watts or lower will work, but it MUST be of 3 ohms impedance.
Jun 14, 2010 | Samsung HTZ-510 Theater System
Wire disconnect from left earphones
Time for some ingenuity.Disassemble the housing to get to the wire connections.The solder pads where the wires go are usually marked + or minus(-). The white/colored wire(signal) goes on the + side.This could be a red dot. The other wire (black) goes on the other pad(-). These wires are so fine they sometimes use nylon thread to give it a lil strength.Good Luck! dnbbgy
May 30, 2010 | Bose TriPort Consumer Headphones
One speaker doesn't work
check the cord and make sure that it is not frayed or damaged at any spot. If it is you can replace them for about 15-20 bucks. If it is something else I would contact Bose directly they do stand behind their products very well ... hope this helps
Apr 06, 2010 | Bose QuietComfort 3 Acoustic Noise...
Getting the sound on the right speaker only
Its likely a broken wire. You can take them apart if you are careful and re solder the wire if you have the tools and are ok with doing that. its a little tricky. if you need more help email me. n_raven99(at)hotmail.com
Mar 20, 2010 | Bose TriPort Consumer Headphones
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Bose 141 will not work
hello in this case this boxes are sealed to ensure a rich sound do this check where they bond together try to apart, im sure you already check with a baterry and ohmeter in the connector of the speaker see how many ohms you have about 4/8 omhs or even a broken wire inside the cabinet cause very old .....saludos
Dec 02, 2008 | Bose 141 Main / Stereo Speaker
Repairing BOSE 901 IV series speakers
The grille will come off if you try to pry it off. Then, unscrew the bad driver. Sort of new ones are sold on E-Bay for not a lot of money. Install the new driver, secure it with screws, and snap the grille back into place.
Apr 24, 2006 | Bose 901 VI Main / Stereo Speaker
Bose  in-ear headphones - Black with black/white cord Logo
74 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
