Question about VinoTemp 28Bottle FreeStanding Wine Cellar Black VT28TEDS Wine Cooler
Vinotemp 28teds doesn't work, no fan, temp or light, what's up
Nothing works. Don't know its history, given to me. No fan, no temp setting, no light, don't see any lint/dust buildup electric cord undamaged, tried different outlets, no results. Do I need to let it sit for 24 hrs, before using it? nothing works!! help.
    Top Expert:
  • VinoTemp Master
  • 34,743 Answers
Probably somewhere in its history there was an incident of total failure.
Posted on Dec 31, 2013
  • Elaine Sampson
    Elaine Sampson Dec 31, 2013
    Can it be used to store wine, to keep it cool, even though it doesn't work.
3 Suggested Answers
  • 8 Answers
SOURCE: Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Posted on Jan 19, 2010
bobicehouse
  • 1524 Answers
SOURCE: My Vinotemp VT52SN stopped cooling.
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Posted on Jul 08, 2011
Why won't my VT60 hold a temperature in the high 50's any longer? It is at 74 and won't let me change it to the 50's.
Make sure all the dust is removed from coils, fan blades and intake vent grill / filter!!! drain the condensation collection pan, and then reset the thermostat and wait 24 hours; before checking the temperature with a digital temp. gauge.
May 06, 2014 | VinoTemp VT-60 Wine Cooler
My vt-tc32g will work for a bit and then stop
If it cycles very irraticly then the temp control could be out of calibration and will need to be replaced. There usually is about a 5-10 degree difference between on and off for the temp control and will be worse with no product in the cooler
Sep 06, 2012 | VinoTemp VT-TC32G
The 3.3 engen overheats but the fan doesn't kick in. I have changed the thermostat but that didn't help the over heating. I hot wired the fan and it will run. ???? Is there a fuse some place i...
Try unplugging the temp sensor located on or near the thermostat housing. This will cause the fan to come on, if it works. If the fan does not come on then check for burnt wires near battery and fuse box. You may need to squeeze and manipulate these wires to find burnt area. I have seen coolant temp sensors, faulty fan motors, and burnt fuseible links cause this. When unpugging the CTS the check engine light will come on, don't worry about it.
Sep 01, 2011 | 1991 Dodge Caravan
My Vinotemp VT52SN stopped cooling. I was away from home for a few days and when I came back the fan was running and the temp was stuck at 62 degrees. I had it set at 54 (and lower)... the fan runs and I...
Jul 08, 2011 | VinoTemp VT-52SN Stainless Steel Wine...
See:
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Unit stop working fan will not turn.
You would have to replace the control board on the unit. You can purchase a new control board from Vinotemp @ 800-777-8466
May 08, 2009 | Refrigerators
VinoTemp 28Bottle FreeStanding Wine Cellar Black VT28TEDS Wine Cooler Logo
215 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
