Question about GE Dishwashers
Doesn't drain or clean
Dishwasher doesn't drain--now dishes are not clean--looks like on bottom and top, although they seem rinsed off--coffee cup on top looked no different. Husband checked what he could, including air gap...no clogs--except he cleaned out stuff stuck in one of contraptions inside the washer. Still doesn't drain, although a little less water at bottom now. He said the arms are going around--he kept opening it while it was running. It is 10 years old. DW repairman? Plumber? New washer???
  • andreamf May 19, 2009
    The model number for problem above..doesn't drain or wash is GSD5130D01WW
  • Leslie Looman
    Leslie Looman May 11, 2010
    need a specific model number please...you can often find them on the inside of the tub wall..or on the bottom of the door ..or behind the kick/toe plate...thank you.
Rotu
  • 175 Answers
SOURCE: stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Posted on Oct 26, 2006
  • 209 Answers
SOURCE: Bosch SHX46A dishwasher
sounds like blockages still, there is also a food filter in the bottom, this has to be cleaned out very regularly, check the waste pipe again also, you may also need salt, this helps the dishwasher keep clean and free from streaks, its special salt you buy just for appliances running hot water first with any domestic automatic appliance is a fairy tail fix, it never ever does any good and can not possibly work by design, all you do is waste hot water?
Posted on Oct 04, 2007
larryyb
  • 291 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
Lower arm repair on Dishwasher?
It will help if you can provide the model number of the kenmore dishwasher. I would try and take the wash arms out and clean them under running tap water. If the residue continues to appear then confirm if the problem is only with the bottom drawer or top drawer as well. Keep a couple of cups on the bottom shelf right side up and check the quality of water in these once dishwasher has drained at end of cycle. Also sometimes if the Rinse aid quantity is low it can lead to residue on glassware.
May 04, 2013 | Kenmore Dishwashers
Dishes are not cleaning well
I often get calls similar to this client: Over the past several weeks-months, have been getting a whitish film/deposit on pots, tops of some plastic cups, etc. You don't really see it on plates.
Typically this is caused when someone switches detergent usually to a liquid gel. It is almost always because we use too much soap.
One of my most appreciated recommendations follows:
My suggestion is to throw the liquid away and use the Cascade Complete or Finish tablets. Place one in the bottom of the dishwasher. Do not put them in the dispenser.
The reason for this is you want the soap (abrasive) at the front end of the cleaning process so that the last little bit of food that is left on the dishes (I'm assuming you are rinsing your dishes) is blasted off and then the dishwasher can "sanitize" the dishes with water that is too hot for you to handle. That is the real purpose of a dishwasher.
Keep in mind that if you rinse your dishes well before placing them in the dishwasher you can probably use the shortest cycle and save quite a bit of money on electricity and water over the course of a year.
Also, take a coffee cup and fill it half way with white vinegar and place it upright in the top rack with your next load of dishes. Do this for the next several loads and then once per month for as long as you own and use a dishwasher.
Sep 02, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
My LG LDF6920St has not been cleaning very well recently and there was an odor and grease left in the bottom after a wash. I pulled it out and found the Float Assembly pretty clogged and dirty, which I...
1 Scrape and rinse dishes before putting them in your appliance. Small food particles, grease, sauces and bones clog up the system, keeping the dishwasher from properly rinsing your dishes. You don't need to prewash the dishes but be sure to rinse off any solids.
2 Use a toothbrush to clean around the dishwasher door.
Clean around the seal and hinges of the dishwasher. This area often is forgotten and holds a good deal of bacteria and food splash. A tooth- or bottlebrush is the best way to get into the crevices.
3 Clean chunks of food out of the screen and drain at the bottom of your dishwasher, recommended The Family Handyman. If the drain is plugged, the dirty water can't be washed away and ends up back on your dishes. Nut, bean and seafood shells, bits of plastic and small dishes can lodge against the drain, keeping it from doing its job.
4 Unclog the holes in the sprayer arms. If the holes are blocked by food or soap, water cannot freely spray inside the dishwasher to thoroughly clean the dishes. Leftover food on the dishes can make the dishwasher smell.
5 Keep space around your dishes. Overloading a dishwasher keeps it from running efficiently, allowing gunk to build up around the drain and the spray arms.
6 Run your dishwasher as hot as possible to break down food and grease. The recommended temperature is 120 F.
7 Run the dishwasher with vinegar added to neutralize odor. Empty the dishwasher, place a dishwasher-safe cup filled with white vinegar on the top rack, and run a cycle at the hottest setting. If you prefer, use unsweetened lemonade powder or baking soda in place of vinegar.
Jun 21, 2011 | LG LDF6920ST Stainless Steel 24 in....
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    I have a hotpoint built in automatic dishwasher model HDA3740G02SA. When my dishwasher runs all the cups on the top shelf seem to have dishwashing soap powder left in the bottom of the cups. I do not...
    make sure the arm on top isnt hitting something, each time you load it each in there and spin it to be sure it moves freely, also make sure your rinse agent container is full of rinse agent.
    Oct 29, 2010 | Hotpoint 24 in. HDA3740G Built-in...
    Dishes/cups are not being completely cleaned. there is grit in the cups on the top rack, along with coffee stains still in the coffee cups. i sometimes pre-rinse, however, i didn't have to w/ my previous...
    1)check the enough inlet water pressure. 2)check any block in the rinse nozzle. 3)check it attains the temperature. 4)check proper detergent& sanitizer going.
    Jun 03, 2010 | Viking 24 in. Professional Series VUD141...
    Dirty cups and baby bottles after dishwasher has been run
    Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
    Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
    Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
    Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
    they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
    Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
    KitchenAid Superba KUDSO1FLSS3 Not Rinsing? No Cleaning at all!
    Here are a couple of things that you can try:
    If there is hard water residue or film left on the dishes:
    Check water hardness.
    If the water is hard, use maximum detergent or try pouring 1/4 cup of Dishwasher Magic into the bottom of the dishwasher. I would also recommend using the High Heat option to ensure proper cleaning. To clean the dishwasher, use a cup of vinegar and place it in the upper rack.
    Detergent carryover:
    If it's below 10 grains, use less detergent and the High Heat option.
    It is also possible that you may have a problem with the drain loop check valve as it's not sealing. This may cause residue or food to be left on the dishes. For this, I would recommend you have a technician do it, as it requires replacing the entire drain loop.
    Let me know if any of this solves the problem.
    Oct 12, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Top shelf items dirtier after cleaning
    After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
    Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwashers Logo
    78 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
