Question about Craftsman 5600 watt Generator
My 5600 crapsman gen has 25 hrs on it was working fine would supply 220 to house fuse panel worked great now will only suppy 120 to panel every thing else runs fine
How can I tell if maker is wired for 220 or 120
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
Nov 04, 2014 | Bunn CWTF Coffee Makers & Espresso...
Powermate 4000 watt gen set shuts down after 10 mins of operation
Coils do develop thermal issues sometimes - replacing it is a good place to start.
Sep 13, 2017 | Coleman Powermate 4000 Watt Generator...
I have a whirpool range top that i purchased that i now realize i do not have 220 V circuit available (replacing a gas range top). I have 120v available. The range top has a sticker that says 'connect...
It will not operate. The control panel will work but you will have no heat. The top and oven need 220 to actually heat up. The only thing that will work on 120 will be your clock and a warm zone if there's one.
Mar 14, 2011 | Whirlpool Kitchen Ranges
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
Cannon 5600 printer is not receiving power from 220 volts
Sir,
You are suggested to check the power cable if it fine and properly pluged in the printer and check if you printer power adapter is working fine. you can check the Power adapter by the Tester usually avalible at electronics shop.
Oct 20, 2009 | Computers & Internet
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Had thermostates checked and still no heat
How does the dealer know if they are good? Did he come to your home to check it? and if so why did he not check for power to the element? If your heater and t-stats are good the only thing that will prevent your heater from operating is the centrifugal switch on the motor. that's provided your t-stats and heater are in fact good. And you have the full 220 volts suppy to the dryer. Keep in mind the heating element is the only thing that's runs on 220 if you only have 120 powering the unit your timer and motor will still run. you can check the power by removing the plug cover on the dryer, you will have a red,white,and black wires from white to black you will read 120, from white to red you will read 120 and from red to black you will read 220 if you don't read 220 between black and red or 120 from red or black to white you have a power issue and nothing wrong with the dryer. Good luck hope this helps you
Jan 11, 2009 | Roper RES7646KQ Electric Dryer
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Craftsman 5600 watt Generator Logo
29 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
