Question about Panasonic NN-C994S Convection/Microwave Oven
Electrical smell smells - Panasonic NN-C994S Convection/Microwave Oven
Microwave does not "heat" and smells when turned on.
calling the company will be the best suggestion because if the smell is like burning plastic, it will be a problem electrically
Mar 21, 2016 | Microwave Ovens
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Whirlpool over microwave combo has burning smell in microwave
Probably fragments of food burning on the waveguide cover.
Jul 31, 2017 | Microwave Ovens
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
When I press the start button it smells like it is burning
if the is a convection model then the covection coill will smell that way if there is a geese build up and should be ok to use. however you should only smell that if you are using the convection mode.
Nov 27, 2008 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-C994S Convection/Microwave Oven Logo
29 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
