Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 Issue Thank you fixya...I would have paid for a service call on the cabrio washer if it wasn't for your site. Thank you, thank you, thank you!
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Stopping after start with F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you?ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Whirlpool WTW6400SW Top Load Washer
When I start the washer the dial flashes and says F1
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer keeps shutting off and F1 shows up on the display.
Thank you !!
Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
What does the F1 means on a whroolpool cabrio loundry washing machine
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 code when my washer starts the fill up
Hi
Thanks
Rylee
Aug 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
Getting a F1 code, how can I reset it. Can afford professional service.
Thank you !!
Jul 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does F1 code show and the washer stop on my whirlpool cabrio
Thank you !!
Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I turn my machine on and i get a f1 flashing? i clear it and try agian and its ok .Do i need a service call? Or is ther something i can do?
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio Washer shows a F1 code during operation? Can yo help us with this problem? John & Kathy
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove
three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
107 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
