Question about Stairmaster 4600PT Stepper
4600cl shut off at speed 20
Work ok at other speed
  • Stairmaster Master
  • 918 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This sounds like a glitch in the software. The only option to correct this problem is to replace the console PCB. PCB for C40 Console SM27130 SPORTSMITH net
Posted on Sep 29, 2015
After a few minutes will shut off and restart
Check the battery - even if plugged into the wall, it may be causing your issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Apr 01, 2014 | Stairmaster 4600CL Stepper Blue Console...
Keeps Resetting In Middle of Workout
You might try adjusting the speed sensor. It may simply just be that they are not heavy enough to make it turn fast enough to work. The following information should help you to make the adjustment I mentioned. Speed Sensor Testing and Adjustment for Stairmaster 4400cl and 4600cl Steppers Testing and Adjustment of Stairmaster 4600CL and 4400CL Speed Sensor Tools Needed: Volt Meter, 7/16" Wrench
A common misconception about battery powered units, it that it only requires you to step on the pedals to power the console; when in fact the speed sensor plays a major role in powering the console.
If you step on the pedals and they fall to the floor due to the console not powering up so there is no resistance, you should check the speed sensor.
The speed sensor is mounted to the alternator and reads the speed sensor disc when the unit is pedaled producing an AC voltage. The voltage from the speed sensor can be tested at the connection of the speed sensor to the lower control board. The connection is a red and black wire. Using AC setting on your volt meter at its lowest range, place the red lead to the red wire and the black lead to the black wire. Make sure the leads of the volt meter are making a good connection. Now step on the unit and verify the voltage from the speed sensor. A good speed sensor will produce about 3 VAC before the console powers up.
If the voltage is not correct, inspect the adjustment of the speed sensor. It may be necessary to adjust the sensor closer to the speed sensor disc. Proper gap of the speed sensor to the disc is about the thickness of a business card.
Retest unit after making speed sensor adjustment.
Feb 01, 2014 | Stairmaster 4600 Cl Cordless Freeclimber
Manual 4600cl
The following link will take you to our Website. Please click the manuals tab in the middle of the screen. Here you will be able to download the PDF version of the owners and service manuals.
Stairmaster Stepper 4600CL Parts Battery Hub Assembly SPORTSMITH net
Oct 11, 2013 | Stairmaster 4600 Cl Cordless Freeclimber
My Nautilus 4600cl right side slips.Would the drive hub be the probable cause?
Most commonly if one side slips and not the other, you are looking at the drive hub sprocket on the side that is slipping. Chances are, if you are experiencing slipping on one side and not the other, the one that is not slipping, is not far behind. It would be in your best interest to purchase the whole drive hub assembly.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Nov 23, 2012 | Stairmaster 4600CL Stepper Blue Console...
My stairmaster 4600cl screen goes on and off when your on it is there away to test the product
Stairmaster Stepper Speed Sensor Testing and Adjustment 4400CL and...
Feb 12, 2011 | Stairmaster 4600 Cl Cordless Freeclimber
Windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes...
windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes wipers will shut off. When needed again same thing will happen This is on a 2003 Chevrolwt express Va
Feb 09, 2010 | 2003 Chevrolet Express
Looking for a manual for stairmaster 4600 free
Hi, I just purchased a used StairMaster 4600CL last week, and found a link for an owner's manual that covers the StairMaster FreeClimber 4200 PT, 4400 PT/CL, and 4600 PT/CL. This is a free, .pdf download:
http://gymstore.info/manuals/upload/StairMaster/stairmaster_freeclimber_4200_4400_4600pt_cl_c40_om.pdf
Vanessa
Jan 23, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Intermittent speedo for 1991 Honda accord but odometer & trip ok
its a faulty speed sensor or plug to speed sensor could be dirty
Dec 17, 2008 | 2001 Honda Accord
Stairmaster 4600PT Stepper Logo
95 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
