Question about Sanyo DP42746 42 in. Plasma Television
The tv display has no image but audio is present the backlight of the tv is not showing at all and even if you put a flashlight on a angle in the display it will not reveal any image being produced, what can be the cause of this can it be the main board?
  • 53 Answers
Does the backlight come on when you first power up the tv and then go out? This would indicate a backlight issue. There are usually several backlight inverters which all stop when one is broken depending on which one. You cannot check the voltage with a typical multimeter because it is very high, but you can disconnect one at a time until you get a display... it will be dim, but this will tell that it is a backlight issue and which inverter is the problem. It may be a CPU issue also... Honestly, for that tv, you're better off buying a new one. Repairing it isn't cheap or easy.
Posted on Dec 31, 2013
Samsung led tv un55h6203af doesn't have any back light but has sound
If you have done the flashlight test and an image is present on the screen when the light is shined from behind then the backlight or the backlight regulator is defective, both should be replaced.
Feb 16, 2017 | Samsung Televison & Video
Hello, LG 55LE8500, sound is working no picture even logo doesn't show when TV is on. Tried all ready to leave it off the power for some time but no success...
Do the flashlight test to see if the backlight is burned out, shine it behind the screen to see if and image is present.
Jan 26, 2017 | Power Computers & Internet
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
When i switch on my laptop I see the led lights on but the screen is blank. I do not even see the hp icon that shows up initially
Hello !
It is typically the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Aug 19, 2010 | Computers & Internet
Viewsonic vp2000s LCD computer monitor - no image displayed; possible backlight outage.
It is possible that the backlight has quit working. Use a flashlight, held at an angle to the display, to see if there is a faint image visible. If so, then have backlight repaired. Otherwise, try a different input / cable.
Aug 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Green light is on but screen is black
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Sanyo DP42746 42 in. Plasma Television Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
