Question about TrendyDigital Padpal tm Convertible Leather Case With
Padpal 7 starts but fails to boot up
Unit starts, but fails to boot up. After a few minutes shuts down
How doo i fix my boost max i tried holding the volume button and hold the power button also but only a red light shows up dosent turn on
Dies it shut down completely when you hold down the power button? If it does however you shut it down do it. Leave it sitting for about 10-15 minutes and try turning it on. If that doesn't work just re format it or re boot it
Feb 19, 2015 | Tablets & eReaders
How do I boot up my Kindle tablet?
Charge Unit for 2 hours then hold start button down for up to two minutes and then release start button. Keep Kindle plugged into charger while doing this. Rich
Jan 05, 2015 | Amazon Sealed Kindle Fire, Full Color 7"...
My PadPal keeps losing the internet connection. I can sit right beside the router/modem and it still loses it. I can't download any games or apps because it won't stay connected. I know everyone bl
You should reset the router. Just unplug the power for about one minute and then reinsert the plug. It will take again about one minute before the router comes back. but after that it should work again. Unplugging, will clear the memory from a lot of clutter, but the settings will be saved.
Eventually you can reset the tablet too. You have to make sure you did install the WiFi settings correct on your tablet.
Jun 21, 2014 | TrendyDigital Padpal tm Convertible...
PadPal 7 tablet stand/ holder wanted
You will find many iPad Holders Accessories with various style and size at complement. They provide wide range of office accessories like laptop stand, monitor stand and many more.
Jan 30, 2014 | TrendyDigital Padpal tm Convertible...
Padpal 7 won't load
Try wiggling the recharging cable (when it's plugged into the unit) or pop out the memory card if you've added on. I bought one (big mistake)- the recharging cable part that sticks into the usb port on the unit is so sloppy loose I have to prop it so it doesn't fall out from any vibrations..
Dec 31, 2013 | TrendyDigital Padpal tm Convertible...
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by...
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
May 03, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
SATELLITE M35X-S329 sartup problem and freezes
I worked on one of these a few months back, it about drove me the nuthouse!!!!!!! after some long hours of going over every chip and connection in that laptop, and by now a couple more gray hairs, I started my search for help. It turns out there was a class action law suit for this product (not sure now on date) but I'm sure of the M35X. There is a issue with stress fractures in the motherboard, along with a couple of bad soldering connections on the board as well. This one I was working on was so strange it even started to boot as I had the HD half way out of the machine and no battery!!! Sounds like you need a new board, sorry! Just make sure if you do, get a good warranty and extend it!
Sep 16, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Wifi fails to resume
Go to Start/Control Panel/Network and Sharing/
then click on View Status, then Diagnose. That usually restarts your wifi so you can be back online without restarting Vista.
May 13, 2008 | Compaq 2710p Tablet PC
TrendyDigital Padpal tm Convertible Leather Case With Logo
Top TrendyDigital Tablets & eReaders Experts
Are you a TrendyDigital Tablet and eReader Expert? Answer questions, earn points and help others
