Question about Honeywell HZ519 Baseboard Heater
My heater is not working at all only my power supply light is on
    Problem Solver:
  • 14 Answers
Unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
Posted on Jan 10, 2014
1994. Why is there no power on fuse that controls cluster lights, a/c and heater controls, cigar lighter light and ash receiver light, radio lamps and overdrive?
Looks as if it is a 4amp fuse and power comes from the headlight switch. Do park lights work? Looks as if 20amp fuse to headlight switch controls park lights and possibly power supply through switch to 4amp fuse. This diagram is for a 6cyl and should be the same as an 8cyl. Hope it helps
Sep 13, 2015 | Dodge Dakota Cars & Trucks
I have a 1997 prowler can't get hot water heater to light
Insects commonly get into the gas supply line just behind the lighting orifice. Try blowing out the line with compressed air. This sometimes requires disassembly of the supply line. This is assuming you have tryed the proper lighting method that the MFG instructions list on the gas device you are lighting. Also check to see if you have a electrical powered gas valve. And if you do make sure that it has power going to the valve allowing it to open when it's calling for gas.
Jan 21, 2015 | Water Water Heaters
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a volt meter and would like to use it to test some connections to figure out the heater does not light. Can you tell me where to place the leads?
First start at the line voltage coming into the unit. The LD model is supplied power from an external source. Once line (supply) voltage is checked, start at the transformer and trace all the circuitry. Meter set at 50 VAC should do it. The supply voltage will supply 120 VAC to the igniter. Here is a link to the PDF manual fro Laars/Jandy/Waterpik Lite2 heater
Jun 06, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
WONT START AND LIGHTS FLASH
try interrupting power to reset.if it still doesnt work consult manual for code to flashing light sequence.also make gas supply is on
Jun 23, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have to heat up my CRT
it is a weak cathode heater inside the CRT. One fix, besides what you are doing, is to replace the glass tube (crt) inside the monitor. Unless you can find a used one, may be hard to find now. It may also be possible to supply the heater filament with a separate supply. I believe this requires a 6 volt supply, so try adding a 10 volt (FUSED- 2 amp) supply to the filament only.
Nov 20, 2007 | Computers & Internet
Honeywell HZ519 Baseboard Heater Logo
422 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
