Question about Honeywell HZ519 Baseboard Heater
My heater is not working at all only supply light working but the heat is not working
Ultima65 laminator wont heat
I would look for a fuse first, then it might be a heater problem
Jan 22, 2015 | Light Office Equipment & Supplies
My heater is not working at all only my power supply light is on
unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 31, 2013 | Honeywell HZ519 Baseboard Heater
New heat exchanger fitted still not heating
The heat exchanger is everything above the fire and makes the heat available for ducting. The combustion chamber supply\'s heat to it from either a burner or heating elements. Does your burner light or elements get hot? Check for power turned off.?
Nov 11, 2013 | Bosch & Power Vent Water Heater
I own an older Jandy Lite 2. The pilot light is on. After the heater runs for a while it gwets very hot and then turns off making it impossible to re-start. Electician restarted by replacing wire that...
over temp situation causing high limits to open. inspect venting, heat exchanger. ensure proper gas/air mixture, proper ventilation and combustion air supply
Aug 19, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
My reddy 30 heater will not stay lit after starting, I have held the switch down for longer than 30 sec, but it just want stay lit
The thermocouple is what tells the gas valve to supply or not supply gas. Several things can cause the thermocouple to malfuntion.
1. pilot light jet is clogged and will not allow the pilot light to reach and heat the thermocouple. Repair by cleaning the pilot light jet out.
2. corrosion on the thermocouple which will also not allow the flame from the pilot to heat the thermocouple properly. Repair by sanding the thermocouple lightly with sandpaper
3. Thermocouple is bad and needs replacement.
Mar 25, 2010 | Heating & Cooling
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Honeywell HZ519 Baseboard Heater Logo
160 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
