Question about Tappan TGF657 Gas Kitchen Range
Oven will not heat up, I can not hear any gas or smell any when attempting to light the oven
  • Tappan Master
  • 3,361 Answers
If the pilot is lit in the oven and does not light, the thermocouple on the gas valve is bad. The entire gas valve must be replaced.
Posted on May 19, 2009
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven smells like gas when trying to light
What is the model number of the unit?
Nov 13, 2012 | Kitchen Ranges
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
Oven not heating
On the bottom is a link of what your oven is. I'm pretty sure it's the ingnightor #16. You should see a glow red hot when you turn on the oven or broil. Very common problem and pretty reasonable price to repair. Unless that glows and get's red hot, it will not turn on the gas. I think that should do it. Let me know if you need anything else. Scott
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=SF325PEEQ0&productCategoryId=0124002&brandId=1198&modelName=Free-Standing,-Gas
Apr 19, 2009 | Kitchen Ranges
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
408 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
