Question about Plumbing
Pump for a ten ft pool pump - Plumbing
    Champion:
    Habit-Forming:
  • 210 Answers
Are you trying to find a pump or install one? Oftentimes you can call local pool companies like http://www.paradise-poolservice.com/services.html that could help you. If you are trying to install it yourself, I would suggest a projects store.
Posted on Feb 04, 2014
Our pool is about 90000 litres of water so how big filter do we need please
If you have a above ground pool go with the Cartridge or sand, and if underground go sand or D.E. All have their ups and down you should find out what you want from them specifically cause they all do varying amounts of the same thing.
Sand Filters
(Filters using literally sand)
For sand filters, on inground pools, I like to use a 30 inch tank diameter, which is a 4.9 sq. ft. filter surface area, and holds 600 lbs of sand. For small pools (under 20,000 gals), I might advise the next size down (24 inch tank), if the budget is tight. But never go smaller than a this for an inground pool.
Cartridge Filters (like a air filter)
I have a rule of thumb for cartridge pool filters. 100 sq. ft. of filter surface area per 10,000 gals of pool water, as a minimum. I like to see the 400 sq. ft. models on inground pools above 25,000 gals. These can go an entire season without cleaning in most cases.
D.E. Filters (Ground up fossilized algae)
Because they offer the most superior type of filtration, people tend to go small with DE, and buy a 24 or 36 sq. ft. DE filter. Ugh - go Big! Nothing below a 48 sq. ft. filter, and if your pool is over 25,000 gals, go with the Big Boy - the 60 sq. ft. filter.
Swimming Pool Blog
Also make sure the filter can take the amount of water that the pump is pushing through it.
Jul 23, 2015 | Pool & Spa
How do you empty the pool so it doesn't go all over the driveway?
attach your vacuum hose to the pump outlet and use the filtervto pump the pool out where you want it.
Sep 08, 2014 | Intex Rectangle Ultra Frame Pools 18 Ft X...
How many gallons of water are in a pool 16 ft wide 32 ft long 4 ft deep
Approximately 15,300 gallons assuming the 4' depth is pool bottom to waterline.
Aug 13, 2014 | Pool & Spa
Where do I find instruction manual(s) for Hayward Super Pump 15 HP SINGLE Speed W C17502 175 Sq Ft Cartridge Filter? Thanks
Copy and paste this link. It will take you to Hayward's main page, from there you can get any books you need.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1_13502_13502_I.htm
Nov 22, 2010 | Hayward Super Pump 15 HP SINGLE Speed W...
My above ground pool overflowed onto the Hayward Pump and now the GFCI just Pops when the pump is plugged in. What do I have to do to the Pump. Seems water may have got in to it. Thanks Graham Payne
UNFORTUNATELY YOUR PUMP IS MOST LIKELY SORTED
IT IS POSSIBLE IT MAY DRY OUT HOWEVER UNLIKELY
STRONGLY RECOMMEND TO EVERYONE MOUNT OR HAVE EQUIPMENT MOUNTED AT LEAST 5 FT AWAY FROM POOL 1 TO 1.5 FT HIGH
MANY LOCAL POOL STORES CAN TEST YOUR MOTOR TO TELL YOU FOR CERTAIN. HOPE THIS HELPS.--CHARLIE POOL PROS
Aug 29, 2010 | Hayward SP1580 PowerFlo LX Series 1HP Pump...
Pool pump shutting down -- heater?
Trying to get the TA correct before you kill the alge? Leslies diagnosis?
You probally just need to kill the alge before you do anything. Nevermind the TA for now and just add about ten gallons of liquid chlorine. The alge untill you kill it will plug the filter constantly. This will give you the code on the heater and will make the pump run very hot and will hurt the plumbing by shrinking it. This will stop water flo by letting air in also it will leak water at the pump discharge.
A lot of liquid will break the alge as it is unstable, but use a lot.Once you kill the most of the alge then add probally another four gallons and now brugh the whole thing real good. now you can start running again and start with all the stuff they will sell you to adjust the PH and TA. I hope this helps, and good luck.
Jul 13, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a 24 ft pool with a sand filter. I use a hayward 1.5 hp pump. I just bought the pool in 2006 and the new filter in 2008. My problem is my pool is always cloudy even after backwashing and adding...
It sounds like your ph is out of whack.
Take some pool water to your local pool store, have them check water quality and ph....most pool store will check for free.
Hope this helps
Jun 20, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Plumbing Logo
5,896 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
