Question about TrendyDigital Padpal tm Convertible Leather Case With
Padpal 7 won't load
When the padpal is turned on only the logo appears, and the unit does not start loading. After a few minutes the unit shuts down.
  • 20 Answers
Try wiggling the recharging cable (when it's plugged into the unit) or pop out the memory card if you've added on. I bought one (big mistake)- the recharging cable part that sticks into the usb port on the unit is so sloppy loose I have to prop it so it doesn't fall out from any vibrations..
Posted on Mar 17, 2014
  • Lo Mc Jul 26, 2014
    Same here, the charger connection is loose so I make sure it's plugged in well at the usb port, set the tablet down gently to ensure it's still charging (look for the tiny blue light on the frame to indicate it's charging). As for the issue of it not powering up but rather staying on the logo only, ours does that occasionally and it seems to be if I press+release the power button too quickly to turn it on (when it's off completely). By pressing + holding the power button for a full second, the unit powers up, shows the logo then proceeds to load with the "rainbow" colours before going to the homescreen. Hope that's all that's wrong with yours + it helps. Sometimes taking the charger out, putting it back in (check for blue light), then powering it up again, holding the power button in for a second or two also helps. Try turning tablet on with AND without the charger in. Our 7" Padpal was on sale $50, dual cameras are low resolution + the processor is mind-numbingly slow so email/internet surfing can be frustrating but it's still a fun, cheap tablet that we use more for games + as an e-reader.
  • Catherine Lundgren
    Catherine Lundgren Jul 26, 2014
    I've more or less resigned myself to the fact that PadPal is a piece of junk but a good paperweight.
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Wont load software
you may have to do a factory reset. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 16, 2014 | RCA Tablets & eReaders
PadPal 7 tablet stand/ holder wanted
You will find many iPad Holders Accessories with various style and size at complement. They provide wide range of office accessories like laptop stand, monitor stand and many more.
Jan 30, 2014 | TrendyDigital Padpal tm Convertible...
How do i fix my polaroid 7" tablet
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Nov 17, 2013 | Southern Telecom PMID706 Polaroid 7"...
Android tablet won't load
http://www.pandawillforum.com/showthread.php?15703-Universal-WM8650-Uberoid-v12-1-(CUSTOM-ROM)
Feb 10, 2013 | Android 7 inch Tablet
Icecream sandwich will not load. ?????
I think it would help others get a better understanding if you posted what brand tablet you're using. Motorola Zoom, Apple iPad 2, Asus Transformer Prime, etc. It could be a known issue with the particular brand.
Sep 21, 2012 | Polaroid 7-in. Internet Tablet - Other
Wont start up the screen only displays the android logo i've tried pressing the reset button many times but still the same
Try a master reset:
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Oct 08, 2011 | Coby Kyros 7" Touchscreen Tablet
TrendyDigital Padpal tm Convertible Leather Case With Logo
289 people viewed this question
Top TrendyDigital Tablets & eReaders Experts
Are you a TrendyDigital Tablet and eReader Expert? Answer questions, earn points and help others
