Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
Setting up the pump for the pool - Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
  • 3,103 Answers
Instructions came with the pool..follow them..really??
Posted on Jan 09, 2014
What would be the best automatic pool cleaner for intex 18 x 48 easy set
the vacuum you are using is probably the best for the system you have. if you want a REAL pool vacuum, get a REAL pool. there is a reason that these are considered disposable pools. dont get me wrong, any way to cool off is great and these pools allow people this 'luxury' at a reasonable cost but they are assembled with low end, non standardized equipment that doesnt match with traditional pool equipment.
Sep 09, 2014 | Intex 18 ft x 48" Easy Set Inflatable...
How do you bleed the lines to the pump?
I usually run a water hose down the skimmer basket drain for a while until water is returning to the pool through the pump. I hope this helps.
Aug 13, 2011 | Intex 15' X 42" Easy Set Pool Complete...
I have forgotten what hose connects to what from pool to pump. above ground simple pool pump.
Discharge of pump goes into inlet of filter, outlet of filter goes back to pool.
Line from pool skimmer or bottom goes into inlet of pump.
Dec 21, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only: how to converte to larger filter...
You can simply buy a larger pool filter that is designed for pools in your size range. Look for one that is designed for smaller above ground pools. You can find lots of different pool filters at backyardcitypools.com.
May 17, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
I have a intex pool
go to intex.com and watch the video
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
How do we get our pool pump back to filtering the pool? It was working for the first day! Now it not doing anything and we have taken the hoses off and did the air in the pipes check, and still not working...
Make sure the selector on the filter is set to "filter" also check that there isn't any obstruction found in the intake pipe coming from the pool to the pump. Make sure the pre-filter basket just before the pump is clean and free from obstruction. Check all valving is open on the intake pipes and discharge pipes exiting the filter.
Jul 05, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I purchased a 15'x42'' easy set pool with no pump
I would agree on the turnover. Don't know if this is a self-priming pump or not. If not, it has to be installed below the top of the pool -- but I assume that's what you're doing, anyway.
May 29, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
51 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
