Question about Allegro DVD/VCR ABV511
Universal remote att - Allegro DVD/VCR ABV511
Tip
Programming AT&T Uverse Universal Remote Control
How to Manually program the AT&T Universal Remote Control to your
TV here are the steps.
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink twice then enter the code 922. The ATT button will blink Thrice. If not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is 25. Dont worry its the volume of the receiver
To Program Your TV:
* Press the TV button and the OK button at the same time for 2-3 sec. release them at the same time. The TV button will blink twice then enter the code. Click Here to see the manufacturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note: After you program the tv make sure to press the ATT button. then now check all the function of the remote. Follow the instruction and it will work. If you press the power button the TV and ATT Recievier will turn on and off at the same time
on Feb 03, 2011 | Televison & Video
Programing att universal remote
Frankly I doubt the ATT remote with the limited number of codes will even program for this set, see if the remote has a search mode which would allow you to try each and every code in it one at a time.
Dec 22, 2012 | Element Electronics Televison & Video
How do I put the code in the in the at&t universal control
To Program Your TV:
May 02, 2011 | JVC AV-32D305 32" TV
Need att remote control mfg. no. for magnavox tv
i do not think it would work with your tv. there has been problems when tech installed uverse on dozens of tv. you can try to purchase an universal remote and see if that works. it is just like a jvc vcr/dvd player/recorder which will not work with any tv but jvc. you can also call att tech to help
Mar 05, 2010 | Televison & Video
My att universal remote will not work, I used all emerson"s codes
my att remote does not work the att dvr cable box unless I'm within one inch of the DVR why?
Jun 25, 2009 | Zenith B19A02D 19" TV
Att uverse codes/Cisco dvr box
is ipn 330hd the model number for the cisco scientrific atlanta box
Apr 28, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
20 people viewed this question
Top Allegro Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Repairing
Computer Repairing
ray gallant
Are you an Allegro Televison and Video Expert? Answer questions, earn points and help others
