Question about Proscan Tablets & eReaders
Power button stuck in tablet - Proscan Tablets & eReaders
Power button stuck on tablet
Radio Shack has 8 air cleaner that also has a composite resolution in it that will unfreeze the buttonbe prepared to spend about 12 to 15 dollars for a 6 ounce can
Dec 31, 2014 | Irulu 7" Google Android 4.0 Capacitive...
My trio stealth- 8 powers on but won't boot up and the reset button just keeps powering it off what can I do to fix my tablet?????
One of the common solutions from YouTube videos short of more drastic measures would be to hold the power button for 10 seconds.
The below videos may help or will if you must resort to a hard reset - that will wipe all files and restore to original.
3 RESET WAYS on ANDROID TABLETS REVIEW 2nd n/a (pattern lock) Android Tablet stuck on boot screen Bypass it in easy steps Android tablet stuck on Android Logo Fix
Dec 29, 2014 | Tablets & eReaders
How do i fix my tablet's screen and power button?
You can likely free the power button by getting in the crevices (long nails work great) and pulling the power button out, or clearing contaminants. Additionally, you might have to access your hard drive through a computer and delete some app data or pictures to free memory and solve the freezing problem.
Jul 18, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Why is my maxtouuch android tablet stuck on start up screen
has the tablet got a reset button hole if not try this ..try holding the power button down for about 30 seconds to c if it will reset if this does nothing hold down power button and volume button at the same time for 30 sec or more. good luck
Jul 11, 2014 | Tablets & eReaders
My tagital tablet stuck on android screen
Hold down the power button for 30 seconds and then turn it back on.
May 01, 2014 | Tagital TM 7" Android 4.0 4GB MID...
Button power stuck
  1. Please check the warranty of your tablet and bring it to the nearest service center if possible because it need an expert in changing parts specially ultra tin tablet like yours because it is very sensitive
Apr 29, 2014 | 8 inch Google Android 2.2 Tablet...
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
Coby mid7048 won't boot past Android screen and won't turn off
Press and hold the power button for about 20 seconds. It should hard reset. If it still get stuck. Power it off. Press the power button then press and hold the power + silver back button for about 8 seconds. You should get a menu that will allow you to factory reset the tablet.
Dec 08, 2013 | Coby Kyros MID7048 7" 4 GB Slate Tablet -...
Button stuck on tablet
Dear Michael,
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
Hope you may find this info helpful!
Best regards,
Miguel Luiz Martins
Apr 28, 2012 | Epad Android 2.3 7inch Touch Screen Tablet...
Tablets & eReaders Logo
24 people viewed this question
Top Proscan Tablets & eReaders Experts
CrisO
tosin_christ
David Payne
David Payne
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
