Question about Proscan Tablets & eReaders
The power button on my tablet got stuck inside of it
Power button stuck on tablet
Radio Shack has 8 air cleaner that also has a composite resolution in it that will unfreeze the buttonbe prepared to spend about 12 to 15 dollars for a 6 ounce can
Dec 31, 2014 | Irulu 7" Google Android 4.0 Capacitive...
My trio stealth- 8 powers on but won't boot up and the reset button just keeps powering it off what can I do to fix my tablet?????
One of the common solutions from YouTube videos short of more drastic measures would be to hold the power button for 10 seconds.
The below videos may help or will if you must resort to a hard reset - that will wipe all files and restore to original.
3 RESET WAYS on ANDROID TABLETS REVIEW 2nd n/a (pattern lock) Android Tablet stuck on boot screen Bypass it in easy steps Android tablet stuck on Android Logo Fix
Dec 29, 2014 | Tablets & eReaders
Why is my maxtouuch android tablet stuck on start up screen
has the tablet got a reset button hole if not try this ..try holding the power button down for about 30 seconds to c if it will reset if this does nothing hold down power button and volume button at the same time for 30 sec or more. good luck
Jul 11, 2014 | Tablets & eReaders
Button power stuck
  1. Please check the warranty of your tablet and bring it to the nearest service center if possible because it need an expert in changing parts specially ultra tin tablet like yours because it is very sensitive
Apr 29, 2014 | 8 inch Google Android 2.2 Tablet...
M9100 boot ans stuck on android screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds.
Debugging mode has to be engaged by running ADB, but becomes quite complex and device specific. Plus it can stop your tablet from working all together, so try this first.
Mar 18, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Wantturn on
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 12, 2014 | Kocaso M760P 1.2GHz 4GB 7" Capacitive...
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
Button stuck on tablet
Dear Michael,
If you have available at your home, try spraying just a little bit of WB40 in the button and try to move it back to its place depressing it and dragging it back with two matches or two toothpicks.
Hope you may find this info helpful!
Best regards,
Miguel Luiz Martins
Apr 28, 2012 | Epad Android 2.3 7inch Touch Screen Tablet...
Tablets & eReaders Logo
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
