Question about Garden
Craftsman LT2000 brakes are failing
6 speed manual transmission 18.5 hp craftsman tractor 2004 and the brakes seem to be failing? can these be tighted or replaced? what is the procedure?
    Sniper:
  • 57 Answers
On the tranxaxle near the right rear wheel is where the brakes are located. There will be a rod going back to a lever. This lever will have a nut on it. Tighten the nut with a 1/2" wrench. With the transmission in neutral on level ground ensure the mower can be moved with slight resistance.
Posted on May 19, 2009
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Transaxle slipping
it has a manual peerless transmission with the brake attached it has broken a gear in the transmission attached to the brake you will have to take it in but it would be better to buy a new one the other is to old
Aug 13, 2013 | Garden
Craftsman lt2000
Garden tractors have a crash style gearbox ( no syncro ) so if there is any movment or drag on the gearbox pulley it will not change gear, this is a belt issue or belt adjustment issue, if the belt is too short or is sagging down so as it is snatching on the pulley you will struggle to change gear.
Jul 02, 2013 | Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where can I find the manual for a garden tractor Craftsman model 944.604192 18 hp LT2000?
You can find that on the Sears site that has all the manual downloads. They are here. Sears has 2,054 lawn tractor manuals on here. Yours should be there.
http://www.managemylife.com/mmh/owner_manuals/search?query=Lawn, tractor
Jun 11, 2011 | Craftsman Garden
Craftsman LT2000 transmission won't engage
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
Nov 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2004 y2000 6 speed manual, and the brakes are
look on the side of trans you will see a small
disc that is your brake there should be a 10mm or 3/8 nut there tighten this nut your brakes should come back.
May 18, 2009 | Craftsman Tractor Steering Knob
Garden Logo
470 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
