Question about Dyson DC28 Animal Bagless Upright Vacuum
Carpet selector and brush bar
The carpet selector does not light up and will not change. The brush bar does not work but turns freely.
  • Official Brand Answer
  • 2,572 Answers
Hi Ken, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC28. To confirm what's causing the issue with the brush bar we'll need to take you through some quick diagnostic checks when you have your machine easily to hand.
So we can help further, please email askdysonUS@dyson.com with your full contact details and the serial number of your machine. One of my colleagues will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Posted on Jan 03, 2014
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
chrispurs1
  • 372 Answers
SOURCE: Brush on Dyson does not turn ....belt not broken
Hi.
Your machine has 2 belts one goes clutch to brush roller second is motor to clutch.
You need to remove the clutch unit from the machine & replace the motor to clutch belt.
Its A lot to try and explain try this site for help.
http://dysonmanuals.llc.nu/
Posted on Jan 11, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
Vac Belts
  • 701 Answers
SOURCE: The brush will not turn. It makes a grinding
It might be that the drive belt is stretched, broken or worn. It can cause the brush to not turn and it will make funny noises. I would try changing the belt. You can get a replacement here:
Dyson DC17 Belt
Posted on Nov 13, 2009
Vac Belts
  • 701 Answers
SOURCE: Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Posted on Dec 05, 2009
White carpet height button flashes
Hi, it's Jack at Dyson.
DC28's carpet height buttons will flash to let you know if you have the carpet height set too low for effective cleaning. Raising the brush bar to the next available height on the selector pad should resolve this.
If you find it continues to flash, it would be worth checking the cleaner head to ensure there are no obstructions. It's also a good idea to remove any threads or hair from around the brush bar:
If you'd like further advice from our experts after giving this a try, please give us a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jul 17, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
White carpet height buttons flash
Hi there, it's Jack at Dyson.
Jul 17, 2014 | Dyson DC28 Animal HEPA Bagless Upright...
My dyson 33 's roller brush will not spin belt is in tact,i have suction with the hose and hand tools, just not when i am using vacuum reg
Hi Edna,
I am sorry to hear your brush bar is not spinning. If your brush bar is clear of all debris, it may be necessary to reset your brush bar. In order to do this please ensure your machine is turned off and unplugged. With your machine in the upright position please rotate the selector knob between the bare floor and carpet setting ten times, ultimately leaving it in the carpet setting. Please proceed to plug your machine in and power it on to determine if the problem is resolved.
If the issue persists please call our Helpline to speak with an expert:
US - 1-866-693-9766 or UK 0800 298 0298
Best wishes,
Jessica
Sep 06, 2013 | Dyson Vacuums
Dc41animal leaves obvious tracks on beige carpet
Hi Alan, it's Jack at Dyson.
Like all Dyson upright vacuums, DC41 Animal includes a motor-driven rotating brush bar. This includes stiff nylon bristle tufts which sweep into the carpet pile, agitating out dust, grit and stubborn pet hair. This will also have the effect of raising the carpet pile where it's been trodden down from daily use - this is what causes the tracks you've noticed. You can see how DC41's brush bar and cleaner head are engineered to work in the video I've attached.
It is possible to turn off the brush bar using the silver brush control switch next to the red on/off switch. However, the brush bar is an important factor in effective carpet cleaning and we would always recommend vacuuming carpets with the brush bar turned on - with the exception of delicate carpets or rugs.
It does sound like your machine is working correctly, in the way it was designed. I hope this information is useful to you, but if you would like some further advice, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
www.dyson.com
Aug 09, 2013 | Dyson DC25 All Floors Bagless Upright...
Kirby Heritage II. Beater bar does not turn. One end rotates freely, but the other sticks, preventing the bar from rotating. No obvious means to disassemble the end of the bar. Is there a way to repair...
The bearing is bad on the end that turns hard. You will need to purchase a new brush roll assembly. If the roller is older that 4 or 5 years, it should be changed anyway. The brush strips that scrub the carpet loose their strength after many years of combing through the carpet, so it's a good idea to change it every 5 years or so.
Oct 03, 2009 | Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Carpet height selector doesn't work.
You have a bad belt. It may not be broke but it's so loose that it isn't turning the brush roller when a little resistance is applied to it. That belt is cheap and it's routine maintenance to change it about every 6 months. You will notice a big difference when you put a new one on.
Nov 22, 2008 | Vacuums
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC28 Animal Bagless Upright Vacuum Logo
81 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
