Question about Canon ImageRUNNER 3570 Copier/Printer
Canon iR 3570
Top paper tray (letter size) copies portrait documents as landscape.  How do we set this back to copy portrait as portrait and landscape as landscape?  Thanks.
  • Anonymous Mar 18, 2014
    When copy a document it looks like it's in code
  • Anonymous Mar 24, 2014
    what is problem my canon ir 2016j poto copy machine blank paper owhat is problem my canon ir 2016j poto copy machine blank paper out
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Tray 1 has defaulted to a landscape orientation--cannot find a way to redirect it to portrait. NOT an issue with placement of paper to be copied.
There's a dial on the front right corner on each paper tray that tells the copier which paper size is loaded in that tray. In the case of letter size paper it also indicates orientation. If the short edge is facing the front of the copier the dial should be on LTR, if the 11" edge is closest to the front the dial should be set on LTRR.
Aug 25, 2011 | Canon imageRUNNER 4570 Copier
I have a Canon 3570 copier that when I put a paper to be copied (portrait formatted) and copy it it will print out in landscape format with half of data cut of. I had a brain surgeon (a fix all) mess with...
just chech the paper size setting paper size in paper cassette maybe the size of paper is not the same position of paper you put inside the cassette tray
Nov 21, 2010 | Canon Office Equipment & Supplies
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Canon iR2016 PCL5e A4 copies have suddenly started to print out in landscape, regardless of any buttons pressed. This means all copies are coming out portrait shape but only printed across the middle. Any...
Check and make sure the paper setting is on what it thinks it is. In other words, make sure the the paper in the tray is letter and the display says letter, instead of letter-r (letter-r runs the long way from side to side in the tray, and letter runs the long way from front to back in the tray) or any other size. I am not familiar with the set up of the paper trays on that machine, but if you have to program the paper size yourself, make sure it is what it is.
Oct 27, 2009 | Canon iR 2016i Black and White Copier
Cannon 2200 always copies in landscape mode
Hello sir;At least you have to set up one paper tray to portrait direction, then when you make copy, use auto select tray. check user guide how to program it.
Jun 03, 2009 | Canon imageRUNNER 2200
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Jan 20, 2009 | HP LaserJet color laser printer
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
458 people viewed this question
old marine
old marine
