Question about Bose Lifestyle 12 5.1 Surround System with Outdoor Speakers & Amp
How do I remove speakers in rear deck of 2010 Cadillac CTS
Wiring for 2006 cts stock radio
2006 Cadillac Deville Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 03, 2016 | 2006 Cadillac CTS
How do I remove and replace the battery in a 2010 Cadillac CTS 3.6 AWD?
Take off anything that is in the way, unbolt whatever holds it in place, take it out, reverse order with new battery.
Dec 02, 2016 | 2010 Cadillac CTS
Replacing battery in a 2010 Cadillac CTS 3.6 awd
Replacing battery in a 2010 Cadillac CTS 3.6 awd ? You don't know where it is or you don't know how to replace a battery ?
Dec 01, 2016 | 2010 Cadillac CTS
How do I remove/replace the battery in my 2010 Cadillac CTS 3.6 AWD.
The battery is in the trunk. Remove the cover over it and disconnect the negative cable first and then the positive, then remove the hold down bolt and left battery out. Make sure you have a low amp 12 volt battery backup attached to the cables so you don't loose all your vehicle settings.
Dec 01, 2016 | 2010 Cadillac CTS 3.6L
How do I reset the anti-teft alarm system?
How to reset an anti theft system on a Cadillac cts - Fixya
www.fixya.com/cars/t13766028-reset_anti_theft_system_cadillac_cts
Jul 26, 2012 - how to reset an anti theft system on a Cadillac cts - Cadillac 2005 CTS... After doing that and making sure the check engine is on you can do .... 2004cadillac cts 3.6 L Theft system locked. ... Nov 28, 2011 ' 2003 Cadillac CTS.
Re: Key stuck, won't crank, service anti theft HELPPPP ...
www.cadillacforums.com/.../cadillac-cts.../190779-key-stuck-wont-crank...
Jan 27, 2010 - 15 posts - ‎7 authors
I really want to do everything that i possibly can. ... Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Key stuck, ... The anti theft light comes on and the "service theft system" message comes ... for 30 minutes at a time to attempt to "reset" everything and still no luck. ... Automobile(s): cts 04,3.6L. Angry Service theft system, traction control light is on ...
Sep 1, 2013
Re: "starting disabled theft problem" HELP
Mar 7, 2013
Re: CTS won't start..Who likes a mystery and a long read ...
Jan 12, 2012
Angry Re: Car won't start-security System
May 25, 2010
More results from www.cadillacforums.com
[PDF]2011 Cadillac CTS/CTS-V Owner Manual
https://www.cadillac.com/.../Cadillac/.../2011_cadillac_cts_owner...
Cadillac
Jan 07, 2016 | Cadillac 2011 CTS 3.6L Performance w/ Navi
How do I make a smaller car speaker fit in a larger opening in the rear dash of a Cadillac cts 2003
Hi Addie, Make an adapter plate that fits your caddy and cut a hole into the adapter plate the size of the speaker you want to fit and fit them. John
Sep 09, 2012 | 2003 Cadillac CTS
How to remove front seat back 2010 cts
Remove the front and rear trim covers over the four bolts that hold the seat to the floor, then go under the seat and disconnect all the wiring being careful not to break any of the connector locking tables.
Jul 12, 2012 | 2010 Cadillac CTS
My back speaker on my 2003 Cadillac CTS rattles. Anything I can do?
go in thru the trunk and see if it is loose, if not then the speaker is blown, remove the speaker and see if a local junk yard has a similar one
Oct 30, 2010 | 2003 Cadillac CTS
The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
Sep 30, 2009 | 2003 Cadillac CTS
Installing 4x10 speakers in the back of a 1984 cadillac eldorado
I can't remember your car exactly but if your speakers are in the rear deck, you often times have to start by removing the bottom portion of the rear seat, then the back portion of the rear seat, then the deck cover. Sometimes the side plastic pieces have to come out too. It's a pain but that is the way it gets done.
Feb 07, 2008 | Car Audio & Video
Bose Lifestyle 12 5.1 Surround System with Outdoor Speakers & Amp Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
