Question about Water Heaters
Hotwater heater thermistor fault - Water Heaters
    New Friend:
  • 16 Answers
The thermostat is a probe installed in the burn chamber accessible by removing the screw or screws holding it on the front of the chamber. If the top of the heater was aligned with the top of your head the thermistor would be about the height of your chin. it has a single wire attached to it and when the screw is removed the thermostat pulls out and looks like a stiff metal wire. Clean it with emery cloth but don't touch the probe with your fingers. Don't be to rough or you will break it. Reinstall and test unit when done
Posted on Jan 16, 2014
  • Ralph Leyba
    Ralph Leyba Jan 16, 2014
    Meant thermistor. Auto correct changed it to thermostat
I have a tf325 bosch hotwater heater , problem is the flame will not stop when hotwater is turned off ?? Why and how to fix
After hot water has been drawn, the refill contents have to be heated to a set temperature in anticipation of the next demand. Otherwise, there would be a rush of cold or lukewarm water instead of hot.
Jan 27, 2015 | Bosch Water Heaters
Ideal icons boiler fault code h1
ideal icos
H1 fault
FLOW THERMISTOR
part number 170917
check wiring to flow thermistor NOT loose first
Sep 16, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
To light the pilot on my OS Smith water heater, I follow the instructions in the label, but nothing happens, no hot water after one hour. Read that there is problems with water heaters, I have some...
Thank you for providing clear description of product:
Your water heater has intellivent gas control thermostat.
There are always problems with water heaters. It is a huge field.
1) Open following link for AO Smith service manuals.
I do not see service manual specifically for the GP series.
http://www.hotwater.com/resources/product-literature/service-handbooks/
2) Open following link to identify gas valve and download typical service manual:
Some AO smith power vent models have intellivent gas valve, and some have smart valve gas vent. Older models might have knob-type gas valve.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 23, 2011 | Water Heaters
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
Whirlpool energy smart gas hotwater heater with flame lock model# SG1J5040TJNOV Product # 0733156 shuts down with an upper sensor failure (controller flashes 6 flash alarm) extinquishing pilot and...
If the water heater shuts off again unplug the white the sensor plug underneath the thermostat (The black plastic box). Then plug it back in. This sensor plug has a black and white wire going to it and it's possible the plug could have been loose going into the thermostat..
If the problem persists you will need to contact the manufacturer at 1-877-817-6750 and they can assist you.
Nov 03, 2010 | Whirlpool Water Heaters
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
I have hotwater in the tank but none at the faucets.
By-pass may be faulty. Are you getting good pressure on hot side, even though not hot?
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
Mar 23, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Small seepage underneath hotwater heater.
soetimes its gaskets around flanges and heater element fixings that fail
have a good look round after drying the area with tissue etc.
leave a dry tissue round the based so you will see tell tale trace stains where its perhaps leaking from
Nov 29, 2008 | Water Heaters
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
