Sony bravia tv problems
All HDMI ports stoped working
  • 451 Answers
1. Turn off the TV and unplug all the HDMI connections to the TV.
2. Turn on the TV and while holding down the up arrow on the remote control, press the power button.
3. The TV will turn itself off, then back on again then release the up arrow button
4. Complete the initial TV setup wizard
5. Turn off the TV and plug back in all the HDMI cables.
6. Check to see if the inputs are working.
Hope this helps.
Posted on Dec 31, 2013
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
  • 8457 Answers
SOURCE: My tv's hdmi wont work
Call the Sony Corp.tell them the prob.their Tech.will come out and replace the board.Ur output control board have sorted parts in it.
Posted on Aug 30, 2009
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
HDMI INPUTS DON'T WORK
It sounds like your set needs servicing. Are the other inputs working? HDMI port failures are indicative of a problem with the main board.
Sep 01, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Feb 19, 2012 | Sony Televison & Video
Where is the HDMI port on a Sony Bravia KDF-46E3000
There are two HDMI (High Definition Multimedia Interface) ports on your Television.Please refer the diagram below to know about the HDMI ports of your Sony Bravia KDF-46E3000.In the diagram the labeled ports numbered 6 and 7 are the two HDMI ports on your television.You can connect your TV with other devices which supports HDMI with an HDMI cable to view High Defenition videos.
Hope you are satisfied with my solution.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
Jul 23, 2011 | Sony Televison & Video
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
HDMI problems with 40'' bravia
The HDMI reciever board in the TV is bad and will need to be replaced. You should have a technician look at it so they can get the correct part number using the model number and the TV's serial number too.
Nov 11, 2009 | Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
Oct 07, 2009 | Sony Televison & Video
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
