Question about Husqvarna Viking 1
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
    Champion:
  • 241 Answers
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Posted on Feb 08, 2014
4 Suggested Answers
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
SOURCE: Viking sewing machine
http://www.sewusa.com/
Go here! FREE!
Posted on Feb 09, 2008
  • 201 Answers
SOURCE: can not adjust the upper thread tension tight
If you are adjusting the upper tension on your machine and yet there is no difference to the sewing, it seems to me that maybe your upper thread is not in the tension disks correctly. Re-thread taking care to make sure the threads bed down into the tension disks. I pull off about 2 foot of thread from the spool and put my right-hand finger on the thread very close to the spool (the idea is to hold it down so it doesn't move) then use my left hand to take the thread through the thread run. Once I get close to the needle, I tug the thread a little and you can hear/feel it go into the tension disk.
Sometimes it looks like the top thread is the problem, but in fact it is the bobbin which is at fault. Re-insert your bobbin again taking care to click it into its tension slot. If you are still getting bad results, try loosening off the bobbin tension. Use a tiny screwdriver to turn the tension screw (the one just on the outside of the tension slot). Turn it no more than 1/5th of a circle at a time (to the right to tighten, to the left to loosen) then put bobbin back in and test. You should not need to adjust it more than two or at most three times. If you do, something is seriously wrong with your machine's tensions and it needs to see the Sewing Machine Doctor.
Posted on Jun 15, 2010
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
sounds very much like insufficient needle tension
Feb 01, 2014 | Sewing Machines
Viking designer se machine Thread that has come out of the take-up lever
Some machines had a special plastic clip that was an update on the thread take up lever. Take it to your dealer for this.
Dec 31, 2013 | Husqvarna Designer I
Designer SE hit pin head while sewing.
did you take out the whole bobin case and see if it has a piece of the broke needle in there?
Jul 22, 2010 | Husqvarna Viking 1
Mc 5700 problem
Check for loose threads or fluff in upper tension unit and bobbin case tension gauged to 14g resistence. Otherwise, service time I'm afraid. Have it serviced by an authorized Husqvarna Viking Service Technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 07, 2008 | Husqvarna Rose
Sewing Machines Logo
69 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
