Question about Peavey Kb-300 150w Electronic Keyboard Amplifier Amp Kb300 Look
I have KB300 keyboard amplification system,power fuse keeps blowing...but no signs of any burns or short in the circuit board...pliz help.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
You have a shorted semiconductor device some where in the unit in the power supply or power amp section, they look just fine when they are worthless, there are techniques for testing these devices...I spent 2 years in school learning some of them...go to this website
http://jacquesricher.com/NEETS/ down load and read modules 1-8 and then read module 16, you may at that time have enough understanding on how to work with semiconductors, remember to use anti-static solder equipment and workstation as these devices are sensitive to static electricity..
every time you fuse your amp you are kicking the crap out of your transformer and eventually it too will be damaged, or take it to the shop.
Posted on Sep 20, 2014
Hi my adcom 5802 get right Chanal not working . I don't know why every time I put 2 fuse for that Chanel is burn st thing look like diot ... And after that 2 fuse burn too
If I can read you right you are saying that the device keeps blowing the fuse?
Fuses blow when there is an overload. As it is an amplifier we are dealing with the cause is more than likely a shorted output transistor or more than one, or whatever does the main amplification for the device. These devices are located on the main power amp board attached to a heat sink. If the amp has fuses for each channel then you only need to replace the devices on that channel, with the fuses blowing on it. The cause of shorted devices is often bad speaker wires or them touching.
Nov 21, 2015 | Adcom Audio Players & Recorders
Power problems
Do you have the schematic for this TV?
Oct 29, 2008 | JVC AV-20420 20" TV
Konzert model AV 502A
Disconnect the speakers, all of them. If the fuse continues blowing off, you have a short circuit in the final stage of the device, called the amplification circuit. If the does not blow , then the short circuit in is one or more speakers.
Jan 18, 2014 | Audio Players & Recorders
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Fuse #109 keep blowing/ driver seat not working please help
If the fuse keeps blowing, I assume it is because you keep replacing it. Those fuses have given up their lives to keep your truck from burning to the ground. Each time a fuse blows, the wires in the system get heated up and weakened. If you keep replacing the fuse, the insulation will eventually burn off of the wires and light the entire truck up. There is a shorted component or wire on one of the circuits that are protected by that fuse. Replacing the fuse without locating and repairing the reason that it blew, will only result in another fuse having to give up its life to keep your truck from roasting and all the other fuses will have died in vain.
The circuits to that fuse will need to be traced, using the wiring diagrams for your vehicle and the proper equipment necessary for performing tests on your electrical system. Nobody online can tell you what the actual cause of the problem is (other than tell you there is a short) without performing the necessary tests on the vehicle itself.
Jan 29, 2011 | 2006 Ford F-150
My car Amp keeps blowing the main fuse, How to find the short?
Hello A4en1, hi, A short circuit need not be burned, the short usually are semiconductors such as ICs and transistors or diodes, I suggest you replace your IC power amplifier.
Mar 29, 2010 | Sony Car Audio & Video
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Window, interior lights, car alarm and fuse keep on burning out
you have a short circuit or burned out wires somewhere, could be anywhere.
Try disconnecting the alarm, taking the bulb out of the interior lights, and putting in the fuse, if it blows again you know that the alarm or interior lights are not at fault, if it stays good replace the bulb and if it blows theres your faulty circuit, if it stays good then the windows are at fault.
Oct 09, 2009 | 2000 Volkswagen Jetta TDI
Fan circuit board on a/c is blowing
You have a short somewhere in your system. It could be anything from a thermostat, thermostat wire or any component in your system. Honestly, you are better off calling a tech.
Feb 22, 2008 | Carrier 52FE312-3 Air Conditioner
Peavey Kb-300 150w Electronic Keyboard Amplifier Amp Kb300 Look Logo
108 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
