Question about Husqvarna Designer I
Viking designer se machine Thread that has come out of the take-up lever
    Champion:
  • 243 Answers
Some machines had a special plastic clip that was an update on the thread take up lever. Take it to your dealer for this.
Posted on Jan 30, 2014
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
SOURCE: Viking sewing machine
http://www.sewusa.com/
Go here! FREE!
Posted on Feb 09, 2008
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
Posted on Feb 14, 2008
SewTechWayne
  • 186 Answers
SOURCE: Service Menu For Husqvarna Designer SE
Hold down the start button and the presser foot pivot buttons at the same time and turn on the power. The machine will make a funny noise and the test screen will come up. You then need to find the sub-menu, I think it says tensions on it but I'm not sure.
Posted on Jan 31, 2009
  • 152 Answers
SOURCE: Designer I software compatibility
You need the Husqvarna Viking software to turn those file extensions into the SHV format. It's about $400 at your dealer. Their web site does a nice job of showing its features. You get over 100 fonts and alot of designs too. You would open your current designs on a screen and then re-write them to the floppy or stick depending on your model of D1. It then sends the stitch information with the picture of the design to the floppy so your D1 can display the image. (The SHV format)
The VIP and HUS format don't carry the image file for your machine so it say's, "file not found", when you try to open them in your D1.
Posted on Oct 24, 2009
My Husqvarna designer SE is not telling me bobbin is empty
Hello, Dene -
Go to this Husqvarna Viking Desinger SE Troubleshooting website:
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_SE_Troubleshooting_EN.pdf
Scroll down Page 1 to the section with the heading "Bobbin Alarm Does Not Work? Follow the instructions there.
If those steps do not get your bobbin sensor back in working order, I suspect you will need to have the bobbin sensor repaired by an authorized Husqvarna Viking sewing machine repair service.
I suggest you contact the Husqvarna Viking sewing machine dealer nearest you and ask about authorized repair businesses.
You can also contact Husqvarna Viking directly:
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST
info@husqvarnaviking.com
Jan 02, 2018 | Husqvarna Sewing Machines
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
Viking Designer SE-Limited Edition 43 hours of sewing. bobbin thread comes up around edges of desing
try changing the needle
check for burrs in the needle plate area & bobbin area
check also the top thread tension
Mar 12, 2012 | Husqvarna Sewing Machines
My Designer 1 embroidery machine thread take-up lever keeps allowing thread to slip off into the inside of the machine. The thread then becomes entagled and wrapped in the gears. I have taken it in twice...
Hi Kathleen
Why don't you ask that question of Viking Husquvarna head office in your country in writing and see if they have now got an aftermarket solution to this problem. Sometimes a direct approach is best.
If the thread take up lever has an open eye and the thread keeps slipping out of this, can you perhaps modify it a little yourself by using a small piece of plastic tape to close off the eye, maybe putting a little grommet in place first so the thread runs freely through it and doesn't catch on the tape. Worth a try?
Jun 21, 2011 | Husqvarna Designer I
I have a designer se the take up lever keeps dropping the thread
Try threading with a figure-of-eight motion - take the thread to the left of the take-up lever hook, across through the hook, then down to the needle. This makes the thread cross itself below the take-up lever hook and may help keep the thread in place. Also be sure that your thread is in the tension disks properly. Always thread with the presser foot raised so the tension disks are open and the thread can seat itself properly. If this does not help, you probably need to see a machine technician.
Aug 02, 2010 | Husqvarna Designer I
My Viking Designer SE Bobbin does not stop winding
I have a Designer Topaz, very similar to yours. There is a small eccentric-shaped piece that rides the thread as the bobbin is filling. On my machine, it can be turned via the little star shaped "torx" depression. This determines the point at which the drive disengages the winding process. In the alternative, when the bobbin is as full as you want it, just push the rider away from the bobbin; the same effect is achieved.
Feb 19, 2010 | Husqvarna Sewing Machines
I have a Designer SE and today while sewing the 'check upper thread' message kept coming up. There was nothing wrong with the thread and I rethread it several times after the message came up. I cleaned...
It's probably the sensor in the upper thread tension unit. If you look where the thread comes to the bottom before looping back up to the take-up lever, there is a small point coming out that holds the thread downward as the takeup lever moves up and down. Take a brush and clean any lint/dust out of that area or it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 08, 2010 | Sewing Machines
Sewing Machines Logo
54 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
