Question about Aquatica Gallery 5 Gallon Koi Magic Aquarium
Did not come up in the bowl
The pump is not working. I put the water in the bowl and turn it on and the light never came on and the water
  • 55 Answers
Try the pump in a small bowl. sometimes the pumps loose thier prime- pour water in the suction side with it running
Posted on Jan 02, 2014
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I have purchased a homemaker rice cooker (5 cup) from Kmart. the owners manual does not tell me how much water to put in for the cooking process.
I think it's the lines on the side of the bowl. For one cup of rice, fill the water up to the first line (with the rice in the bowl), and so on.
Jan 06, 2011 | Vacuums
Bissell 9300 will not spray liquid
I've got the 9300. Same problem occured during warranty period. They replaced the pump and it has worked fine since. The service person said never to put hot water in the tank (whish is what I was doing). If you put hot water in the tank, with the heater on, the water gets boiling hot and then the plastic impeller on the pump expands and the pump shaft simply spins and does not turn the impeller. Don't know if it is true or not, but his explanation sounded reasonable. Since then, I have used only lukewarm water in the tank and it still squirts fine (about 2 years). I also shut the heater off and squirt some fresh water in order to keep the pump cooler if I need to pause the cleaning for more than a few minutes. I took it apart one time to see what is inside. The pump is not real easy to get to. Good luck.
Mar 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 upright carpet cleaner does not spray water. Could it be the pump or solenoid, or both?
It could be the pump. You can open it up and see if the pump is working by taking the pump input tube and inserting it into a bowl of water. Pull the trigger and see if water is leaving at the pump output.
However, ensure you have the simpler things covered first:
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Dec 04, 2009 | Bissell 9200 Upright Vacuum
I don't have instructions for the Rainbow shampooer. I'm not sure how much water to put in, or whether I put water in both reservoirs. Does anyone know?
Water only goes into the cub in the handle. The dirty water gets put into the bowl on the canister part.
Nov 28, 2009 | Rainbow Vacuums
Aquamate II NOT WORKING !!
If this is pre-owned unit that you bought - it may be clogged. If people who had it did not rinse shampoo solution out of the system after using it - shampoo becomes thick and sticky when dry and may clog the tubes. Also it may impair the pump.
Pump may also be defective. It should make a humming noise while in operation. It is hard to hear when vacuum is on so take the Rainbow with water bowl of the white AQM basin, turn on the vacuum while AquaMate is still plugged in, put your hand on the black plastic on the white AquaMater water nontainer and you should feel pump vibrating inside.
If you feel it start with filling up the white tank and bottle with warm water, turn AQM on and try rinsing it. However if water can not get through at all - it will not help.
Then take the handle apart (a bit tricky but be careful ant to break the plastic and you will get it open). See if there are no clogs there. in tubes nor the VALVE.
If no clogs fing - you will have to acces the pomp and few short tubes inside this plastic box assembled onto the water tank. to get it open you may have to break off 4 latches that hold top halve to the bottom. You can purchase one HERE. Make sure that tubes inside are not bent at the sharp angle and obstructing the flow. If you need any tubing - you can find it cheap at Home Depot (have a sample with you so you pick the right diameter).
Clean all tues inside and you possibly will have to take the pump apart to get it cleaned. If it is not working you can buy one HERE.
Stil no luck - put EVERYTHING in a plastic bag or several bags and then in a box and ship it to us - we will get it running.
Good Luck,
Rocky
Mar 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Aquatica Gallery 5 Gallon Koi Magic Aquarium Logo
Top Aquatica Gallery Vacuums Experts
JoeVacs
Are you an Aquatica Gallery Vacuum Expert? Answer questions, earn points and help others
