Question about LG WT4801CW Top Load Washers
LG WT4801CW is leaking water from underneath the tub
3 Suggested Answers
  • 23 Answers
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Posted on Sep 14, 2009
  • 114 Answers
SOURCE: My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Posted on Nov 27, 2012
How do I increase the water level on my LG washer WT4801CW
The level sensor may be defective and should be replaced.
Oct 08, 2016 | LG Washing Machines
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
My LG WM1814CW Washer is gushing water from underneath during every wash. We pulled the washer out and checked the hose lines and everything is fine there. What is underneath that could be leaking? Do we...
sorry about your floor! yes you need to pull it apart and see if anything looks funny-if no hoses are loose the tub may be leaking-this would be happening around the door seal-also try to wiggle the tub to check the tub bearing-which could also cause the leaking-if it seems to be loose this could be the problem also-cheers Denny
Oct 28, 2013 | Washing Machines
LG WT4801CW HE top load washer poor performance.
I think you will find that hair and lint is much more effectively removed in a dryer.
Mar 23, 2017 | LG WT4801CW 3.7 cu. ft. top load washer
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
LG steam washer leaks a small amount of water from underneath the washer between loads.
Hello.
Welcome to Fixya.
  • Inspect the water supply connections.
  • Inspect the drain hose.
  • Inspect the Water Pump.
  • Inspect outer tub for cracks or corrosion.
  • Inspect the tub seal.
  • Inspect the tub bearing.
Good Luck.
May 05, 2009 | LG WM2487H Front Load Washer
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on...
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
  • Inspect the water pump
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Dec 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
LG WT4801CW Top Load Washers Logo
125 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
