Question about Lasonic Ghetto Blaster i931 Boombox
Toshiba rt 130s plugged to wrong power source
Tip
Trailer Wiring
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Jan 16, 2012 | Toshiba Satellite M305-S4826 Laptop
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I PLUGGED IN MY LAPTOP ADAPTER AND THE PLUG LIGHT BLINKS BUT DOES NOT POWER UP. THE PLUG ICON ON LAPTOP BLINKS BUT LAPTOP WILL NOT BOOT UP.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Mar 21, 2011 | Toshiba Satellite A215-S4807 Notebook
I need an A/C adapter for my P25-S5262 Satellite laptop. Online sellers keep sending me adapters with a plug that is too small for the power jack. The latest seller wants to know what the "psp number" is...
ah its because at 6 years old the
Toshiba power source and power input plug you seek
has been discontinued and not superseded
A35 19v 6.3a 120w is a rare power source
one on ebay seller USA list this unit suitable for your
Toshiba Satellite P25-S5262
http://www.ebay.com/itm/NEW-Toshiba-Satellite-P25-P15-Laptop-AC-Power-Adapter-Charger-A35-19v-6-3a-120w-/401167479005
if not correct as in picture
you need to keep a look out online for sale any
used P25-S5262 with working power source
Mar 08, 2017 | Toshiba Satellite P25-S5262 Notebook
Where is GPS power connection on 2007 BMW R1200 RT? I have mount for Garmin Zumo 550. I understand there is a power connector somewhere near the ignition switch, but I can't locate it..
Hi, Dmercier for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Identity source of GPS Power Cord Plug 05 R1200RT
1200 RT gps power connection BMWSportTouring Forums
Bmw r1200rt service manual pdf
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Nov 05, 2009 | 2007 BMW R 1200 RT
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
Lasonic Ghetto Blaster i931 Boombox Logo
62 people viewed this question
Top Lasonic Audio Players & Recorders Experts
Jonathon summesfield
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
