Question about Brother MFC-8460N All-In-One Printer
8460n fuser My fuser fused the rubber roller to the plastic roller. I seperated them, but now it prints out black sheets. what could be the problem?
    New Friend:
    Problem Solver:
  • 5 Answers
Taflon and fuser & praser roller replace problem sol.....
Posted on Dec 31, 2013
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Posted on Jul 29, 2009
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Copies have black roller marks on the right side of each page, getting darker each time. I can print a single sheet, wait, it print again, wait~roller lines aren't as bad, but still present
I could be wrong, but I think it's in the toner cartridge. The drum - the roller that the image is formed on - has a soft, plastic blade rubbing against it to clean off excess toner after each print. If a clump of toner gets stuck under the blade, a line is printed down the page where that part of the drum isn't cleaned as well. Between prints, the drum keeps turning, and may be able to clean itself better than in a single revolution. It's a theory, anyway.
Pull out your toner cartridge and look at the drum to see if there's a black line around it at one end. You can't get to the cleaning blade without risking ruining the drum and the cartridge; the cure is just to get a new cartridge. If yours is fairly new, take it back to the store that sold it to you, along with a print sample. They might exchange it.
If the drum doesn't have a line around it, you can test it by deliberately jamming the machine. It's scary, but if you've unjammed jams before, you can do it again. Start a print job, then kill the power when you think the page is right in the middle of the printer. Open the printer and remove the toner cartridge. Look for that black line on the page before it reaches the drum, between the drum and the fuser, and past the fuser. (The fuser is the pair of hot rollers that pinch the page tightly and melt the powdered image into the paper. Any part of the image that hasn't made it into the fuser is still powder and will rub off.)
If the line doesn't show up until after the hot rollers, then I was wrong about the toner cartridge, and you're looking at a fuser problem.
Mar 11, 2011 | Samsung ML-2510 Laser Printer
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
I loaded a lined sheet of notebook paper into our printer tray to have something print on it. It came up with the message that there was a paper jam and to remove the paper tray and toner cartridge. I...
The only way a paper jam could affect your print quality is if it were actually stuck in the toner/drum cartridge area. I would remove the drum unit and then take the toner cartridge out of the drum unit and make sure there is no paper in either of the 2 units. The only other possibility would be that the sheet of paper wrapped around the fuser roller. This is the area just before the paper exits the machine. This would usually cause the print/toner on the copy to rub off or not be fully "fused" onto the page.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother MFC-8460N All-In-One Printer
Paper keeps jamming after 10 -20 sheets,please help
if your fuser rollers look clean and even it could be pickup issue. It's easy to fix in 3 steps.
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore.
http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Apr 15, 2010 | Brother HL-2040 Laser Printer
Ghostly effect
If drum is a genuine Brother, then open the rear door and look at the fuser rollers, if you see toner or partial images on the rollers you need a new fuser, if the fuser is clean, look at the drum surface and if you see parts of last print then the drum is bad. In reports, print the user options list it will give the total print count. The fuser is worn out around 80 to 100,000 prints.
Jan 11, 2010 | Brother MFC-8460N All-In-One Printer
Lexmark x83 does not pull paper through; what do I do?
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, follow the steps given below to perform the self-test:
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Sep 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
