Question about Danby Dar044a1sldd 4.4 Cu. Ft. Compact Refrigerator Stainless Steel
Finding coolant lines - Danby Dar044a1sldd 4.4 Cu. Ft. Compact Refrigerator Stainless Steel
2001 Ford Expedition 5.4L. I have a coolant leak from the rear of the vehicle near the spare tire. There is a black box with 5 lines coming from it, two refrigarant lines for rear a/c, and 3 others. I am...
coolant line for rear heating of the truck find out if they can be connected. u may see a nipple where the hose goes if so replace with a rubber heater hose. if nipple broke get new box from junk yard, buy new hoses and clamps and reconnect. you may need a/c rubber rings for the two ac lines. remember if replacing the box car should be cold your dealing with coolant. and release pressure from the ac lines before servicing
Jul 28, 2011 | 1998 Ford Expedition
My 2000 saturn show a low coolant level warning light. What do i do to fix that problem?
check coolant if low add to full line now is light out if not then first pressure check cooling system to find out where the missing coolant went then clean coolant tank out good re-fill is light still on then replace coolant level sensor
Sep 16, 2010 | Saturn S-Series Cars & Trucks
1990 BMW 735i: oil in the coolant reservoir
If your car is an automatic there would be lines from the transmission to the rad to cool the transmision fluid. Over time the lines inside the rad have been known to corrode and start leaking. This would put oil in your coolant. You would be looking for small steel lines going in and out that would trace back to the transmission. Hope this helps.
Feb 21, 2010 | 1992 BMW 7 Series
Cant find coolant lines
jack it up on the passenger side and remove the plastic inner fenders this will give you a better view of the cooling system and the hoses below that run to the water pump and radiator.
Jan 16, 2010 | 2001 Ford Taurus
1999 Porsche Carrera leaking coolant. Can't see or find the leak,not enough room underneath. It is leaking directly over the exhaust pipe. Is there a discharge hose in case of overheating that might be the...
the only coolant lines would go from your rad to engine block and lines to your tranny, what part of your exhaust is it dripping on (close to the catalytic converter,or on the tailpipe)??
Nov 19, 2009 | 2000 Porsche 911 Carrera
I have a coolant leak from one of the tranmission lines at the transmission. is that line hard to change? It is the upper line and looks rusty
You dont have coolant running to the auto trans gearbox so whet it is ,,,is the coolant coming from another place and running down the metal pipe to the g/box as its only trans oil in the g/box.
SO start up the front and radiator where ithe pipe starts and run your finger down the pipe slowly and you will find where it starts getting wet and the leak will be above it somewere....
Oct 02, 2009 | 1998 Lincoln Navigator
I am trying to find out how to disassemble the radiator support in my 1999 Chevy Suburban and I am having some difficulities.
  1. Drain the cooling system.
  2. Unfasten the upper fan shroud bolts and remove the upper fan shroud.
  3. If equipped, remove the upper panel fasteners and the panel.
  4. If equipped, remove the upper insulators and brackets.
  5. Disconnect the radiator upper and lower hoses and, if applicable, the transmission coolant lines.
  6. Remove the coolant recovery system line, if so equipped.
  7. Remove the oil coolant lines, if equipped.
  8. Remove the lower fan shroud bolts and the lower fan shroud.
  9. Remove radiator from the lower brackets and insulators.
    0900c152802490af.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the radiator mounting
    0900c152802490b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the radiator upper panel fasteners
    0900c152802490b1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Remove the radiator upper panel
    0900c152802490b2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Disconnect the transmission cooler lines
Sep 02, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Need to find the low line on the 2002 ford focus in order to put coolant in. where is it?
on the coolant recovery tank, use a flashlight it's hard to see. after you find it, use a permant type marker and put a line on it so it's easier to see in the future.
Aug 27, 2009 | 2000 Ford Focus
Where is the high pressure air conditioning coolant valve located on a 98 MPV ?  We are trying to recharge the coolant.  Found the low pressure valve - can't see the high pressure / red one...
Some times they are hard to find.Find the high side line/hose,on the compressor,follow the line until you find the ac high side service port.The small line is the high side,If I can help any further let me know roniecon@gmail.com
Jul 22, 2009 | 1998 Mazda MPV
Danby Dar044a1sldd 4.4 Cu. Ft. Compact Refrigerator Stainless Steel Logo
24 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
