LG ac remote is not working, batteries have been replaced
LG SU/SZ/SZ/S3 remote not working, batteries replaced, ac unit not staying powered on when using on/off switch on the wall mounted unit. Please help!
    Habit-Forming:
  • 109 Answers
Probably the fuse to the indoor unit must replace it. It's on the pcboard and it's from glass. Turn of the power and replace it.
Posted on Jan 01, 2014
4 Suggested Answers
SOURCE: Nothing seems to work
am also facing the same problem
Posted on Jul 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: fan not working on LG air conditioner su/sz/s3 model
Bad fan motor and or start capacitor are reasons that I suspect......Sea Breeze
Posted on Jan 31, 2009
Nomadfeet
  • 59 Answers
SOURCE: I have a 2 wall
The Mitsu remotes use a smart code function- they send all of the data (temp, mode,fan speed,etc.) with each button push. Uni remotes are not built for this in my experience. You may be able to teach it to so with default functions built in, but I've not yet heard of a good solution for this issue.
Posted on Sep 25, 2011
Why LG air conditioner su/sz/s3 model C3 error code
C3 isn't a common LG fault code but from what I remember, its a communication error. Possible wiring or outdoor board failure.
Mar 19, 2016 | LG Heating & Cooling
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
Hi, i have started renting a house just a week ago. Its having an lg split air conditioner in the house.suddenly one day, when i came back from work and tried to turn on the A.C it didn't start. We...
Hi, does the Ac beep when you press the buttons.? Are the batteries in the correct way around. is there power at the AC. All good points to check. If all answers are yes then the chance is that the remote or the AC receiver board is faulty. Col R. digitalcontrols.com.au
Mar 04, 2011 | LG Heating & Cooling
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
Jun 28, 2009 | LG Heat cool Window Air Conditioner
LG SPLIT SYSTEM AC.
Fixed fault by not only switching off AC unit at power point, had to pull out plug top & lead from wall for one minute. This must allow electronics to reset.
Jan 31, 2009 | LG LSC121PMA Split System Air Conditioner
Fan not working on LG air conditioner su/sz/s3 model
Jan 31, 2009 | LG Electronic Window Air Conditioner
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
