Question about Cuisinart CJK-17BC Cordless Electric Kettle
Three beeps and water doesn't boil - Cuisinart CJK-17BC Cordless Electric Kettle
What is the best method for purifying water?
depends on where you are and when you want the water treated.
for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces )
if you want it for home use
running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs
for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best
so you need to specific as to when you want the water pure.
boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
Dec 26, 2016 | Air Purifiers
Tip
How to cook the perfect hardboiled egg
Cooking the perfect hard boiled egg can be surprisingly difficult.
Start by filling a pot with lukewarm water and placing it over a very low heat.
This doesn't need to be the lowest flame setting on your stove top but it should be low.
A good comparison is the flame should be as high as you would have it if you were cooking rice.
Gently place the uncooked eggs into the water.
Pour about a tablespoon of vinegar into the pot. The vinegar will not alter the flavor of your eggs, it will just help the shells peel right off of them when they are ready.
Do not cover the pot.
Keep an eye on the pot for when it boils.
Once the water has come to a rolling boil set your timer for 14 minutes.
Once the timer sounds, remove the eggs with a slotted spoon and place them in a bowl of cool water.
Eggs peel best if they are cold so if you need to peel them right away, do so under a stream of cold water from the faucet. If you can wait, put them in fridge in a closed container so that the sulfur smell doesn't permeate other foods in there. When you're ready to peel them, simply take them out and watch as the shell is removed easily, thanks to the vinegar!
on Oct 07, 2013 | Cooking
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
How hot should fresh perked coffee be from any coffee maker?
some people say that coffee can burn when you pour boiling water on the beans and recommend that you should add the milk first... I just let the kettle cool down until the boiling stop as well. as for espresso makers, water will boil and the gas (liquid to gas at boiling temperature) is pushed through the beans, so its rather hot and the beans doesn't burn.coffee should be as hot as possible!
Apr 02, 2012 | Coffee Makers & Espresso Machines
My friend bought me a hyundai egg cooker(plu 247959) but the instructions only tell you how to soft boil 2 eggs or hard boil 3! and no instructions of other amounts of eggs or how much water to use or how...
Ignore the instruction manual. Instead look at the measuring cup that comes with your Hyundai PLU 247959 (produced and sold under license by Poundstretcher).
On the side of the measuring cup, you can see three clusters of marks:1. 25 to 40 ml for soft-boiled eggs (symbol of egg with two horizontal lines)2. 45 to 60 ml for medium boiled eggs (symbol of egg with one horizontal line)3. 65 to 80 ml for hard boiled eggs (symbol of egg)
Egg boilers are based on the principle that the larger the volume to be heated is, the less water is required. In other words, you will need to add less water for boiling seven eggs, and more water for boiling one or two eggs.
Which means that for seven eggs to soft boil, add 25 ml; and for one egg to soft boil, add 40 ml. If you look at the markings, you'll notice that on the vertical line between 40 and 25 ml, there are seven equidistant horizontal lines, each showing the amount of water required for the various quantities of eggs.
One egg = fill with water up to the 40 ml markTwo eggs = fill up to the mark below the 40 ml markThree eggs = fill up to the second mark below the 40 ml markFour eggs = fill up to the third mark below the 40 ml mark etc, untilSeven eggs = fill up to the 25 ml mark
Medium boiled and hard boiled eggs are measured in similar ways. Works every time for me. Nice little egg boiler, by the way.
Oct 09, 2011 | Back to Basics TEM-500 Egg & Muffin...
Antifreeze boiling over when car is overheatind and Wen its not overheating changed thermostat radiator bled and flushed it changed temperature switch no oil and water mixture No smoke
Check the over flow tank located in front of the passenger side glove box for water or fluid. When driving the car, listen by the glove box to see if you car hear a boiling sound. If you can hear water boiling or moving, check your heater core to make sure it is not plugged or bad. When the car starts to over heat, does the gauge register that it is getting hot? If it doesn't then check the thermostat to make sure it is not stuck open or closed. If its over heating and the gauge is not showing that the car is running hot before boiling over, then the thermostat is defective or not working. Try replacing it again.
Sep 23, 2011 | 2000 Volvo V40
Replace cooling fan termstat and vehicle still over heats
Thermostat
Test thermostat in a jug and pour boiling water on it , it should compress meaning it works. Check that the waterpunp is operating pushing water into the engine .Check that radiator water flows to the watrpump. Is tension of fanbelt of waterpump sufficient that it doenst slip. Lastly check that the radiator fan is working if has a electric fan. if this doesn’t help check if radiator or engine water passages isn’t blocked.
Aug 29, 2009 | 1995 Pontiac Sunfire
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Cuisinart CJK-17BC Cordless Electric Kettle Logo
56 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
