Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
Cannot remove dirt cup for emptying
I know this must be the simplest thing, but i just cannot take it out. i push the release button and try to to swivel it out, but it doesn't come out. how do i do it?
  • jenlira May 19, 2009
    i am pushing the release button. it still won't come out
  • 57 Answers
It has a release button some where , you need to find it...(my wife had same issue...i left her to find it :)..
hope it helps...keep the hope :)
Posted on May 19, 2009
  • suresh chandra May 19, 2009
    sorry..what model is it..
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Why does my dirt devil swerve get really hot?
Hello! Sounds like your vacuum may be overheating. This is usually caused by either a clog or a filter that needs to be cleaned. Please try the steps below to get your vacuum back up and running.
1. Remove the hose from both ends by pressing the release buttons.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the nozzle from the cleaner by pressing the release button and pulling the nozzle from the body.
4. Use a wooden spoon or something similar to loosen up and remove any clogs from the nozzle or the lower tube.
5. Remove the dirt cup. Lift open the lid to the dirt cup.
6. Remove the filter from dirt cup. Remove the filter frame from dirt cup. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
7. Check the exhaust filter by twisting off the filter cover.
8. If dirty, the exhaust filter can be washed as well. Hold filter under running water to rinse. Allow 24 hours to air dry.
This should stop the vacuum from overheating. If not please reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Thanks!
May 27, 2014 | Dirt Devil Swerve Upright Vacuum
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Can't remove the dirt container
Try placing the lever in the unlock position and pull down lightly on the dirt cup.
If you are still having problems with the dirt cup on your unit please contact our Customer Care by phone or email at:
http://www.bissell.com/email-us/?cid=ccsocial
May 31, 2012 | Bissell Vacuums
Does it come apart to empty the dirt?
There is usually some kind of lever that you push to release the dirt cup.
Since all models are different I can't tell where yours is at.
If you can't find it, read the manual. If you don't have a manual, ask your momma.
Look for a lever that says "unlock", or "unlock to empty" or "push to unlock" or "pull to unlock"
etc.
Feb 14, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
I do not know how to remove the canister that catches the dirt. I do not have a manuel.
Sorry to read about your problem, I hope this helps you out.
Emptying the Clear bin caution: (i) switch 'off' and unplug machine before emptying the bin.
Empty as soon as the dirt reaches the level of the MAX mark - do not overfill.
To remove the clear bin from the machine press the button at rear of carrying handle. to release the dirt, press the button again to open the bin.
Please note: (i) Do not use the machine without the clear binin place.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I do not know how to put the container back on the dynamite quick vac after emptying the dirt out?
after emptying the dirt cup make sure that the arrows are lined up on the top and bottom of the cup you have to put the bottom of the cup in at an angle first and make sure that the small handle is pointed towards the cut out in the handle section then just push the top flush with the handle and it should just snap in, i hope this helped let me know all comments are helpful thanks Don the Vacuum Doctor Alb NM
Nov 05, 2009 | Dirt Devil M084600 Dynamite Bagless...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
120 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
