Question about Sony KV-32XBR200 32" TV
Sony wega tv problem
The bottom of the screen is blue and  blue "stars" (penciltip size) are visible on the screen. These stars are taking over the screen. I now have 16 stars on the screen. Is this a picture tube issue?
  • 93 Answers
Re: Sony wega tv problem
No,most of cases is only cause of loose contact.
Posted on Oct 19, 2007
0 characters
3 Points
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15...
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Feb 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Hi, my name is Nicole. My KV-36HS510 Sony TV is being broadcast with the picture size reduced quite a bit. Playing DVD's is fine, the pic fills the whole 36". However on cable TV it is chopped on the...
press "menu"
the setup screen should open
scroll through the options to "16:9 enhanced"
you should find 2 options ("on" and "auto")
choose "auto"
that should do it
Sep 12, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
How do I adjust the screen size on a DVD I'm viewing on my 36" Sony Wego TV? The top and bottom are cropped. Thanks!
On the remote control press the "Screen Mode" button to cycle through all available screen modes.
Apr 20, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony WEGA KV-27FS100 picture size
hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA 42" LCD TV
If these are oth LCD projection have them looked at. The light engine will need to be relaced and has an extended warranty on some models for this case. Call Sony with the serial and model to verify and they can tell you in your area who is a qualified Sony servicer. Circuit City can handle these if they are covered by the light engine warranty.
Oct 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Standard (CRT) Televisions Logo
207 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
