Question about Canon PowerShot SX130 IS Digital Camera
Busy message When i try to take a picture, record, or reset the message "busy" with hand icon appears. When you turn on the camera, you cannot see what you're trying to photograph. What can i do to fix this?
  • 53 Answers
Try a new memory card.
Posted on Dec 31, 2013
3 Suggested Answers
  • 15 Answers
SOURCE: Busy message on computer and camera
Try resetting the camera to factory defaults - Here's how:
  • Firstly press the 'menu' button, then the up button above the 'OK' as many times as needed, until you see the top folders are highlighted.
  • Press the right button near the 'OK' until you see the last folder highlighted. You will know this is highlighted when you see the first menu option that says 'Language'. The 3rd one down from that says 'Clear Settings'.
  • Press the down button under the 'OK' until 'Clear Settings' is highlighted, then press the 'OK' button.
  • Scroll up to your choice and press 'OK' to reset your Canon 400D back to default factory settings.
Hope this helps
Posted on Jun 29, 2008
  • 45 Answers
SOURCE: Conon 350d constant 'busy' message...
Is the memory card locked? Is it bad? Are you using internal memory? First, see if the lock switch is on. Then try putting it in a memory card reader.
Posted on Aug 18, 2008
What does the hand icon and the busy message mean?
The "hand" icon indicates the Image Stabilization is enabled.
The busy message means that the camera is processing the command that was given, mostly it means that the camera is processing the image and writing it onto the memory card.
I will appreciate your feedback and positive rating for this free solution.
Sep 30, 2010 | Canon PowerShot SX100 IS Digital Camera
I have just purchased Canon Powershot A480
I think the "busy" part can be put down to the camera performing a function or recharging the flash. The red icon I THINK shows that the camera is focussing.
With the last model it worked so that you could half press the button to focus on something (eg a fast moving pet) and then once your pet stopped moving your could fully press the button to take a photo and the focus distance would remain the same.
Nov 27, 2009 | Canon PowerShot A480 Digital Camera
A little hand with a no sogn through it and the word busy
The busy sign generally comes when:
Image is being recorded to the memory card, or playback mode is starting up.
It possible your memory card is full, please therefore down load your pictures and try again after erasing and reformating the memory card..
Alternatvely, please also reset all the camera ands menu settings to default.
Hope it works for you.
Mar 02, 2009 | Canon PowerShot A530 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Recording mode
Ha - had the same problem, and after some fiddling realised I was in 'burst' mode instead of single shot! Hit, menu on the camera icon and reset to normal. Good luck!
Aug 24, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Flash
Your camera is set at twilnight mode which has the flash suppressed and you won't be able to turn it on because of the fixed setting of twilnight mode to get the proper result of the picture. Due to the mode setting requirement, a shakey hand icon and no flash icon will show. If you press the flash mode button, it beeps. The twilnight setting has a low shutter speed, i.e. the shutter opens longer to allow more lights in, therefore it shows recording to let you know that the shutter is still open, and any moment of the camera will result in a blurred picture.
Now, check your camera mode dial and turn it back to the 'green' camera and see if you can get the flash to fire.
Jul 08, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot SX130 IS Digital Camera Logo
221 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
