Question about Zhone Computers & Internet
Zhone lan port not working - Zhone Computers & Internet
HOW DO I GET THE WIRELESS TO TURN ON
http://www.zhone.com/support/manuals/router_manuals.n2n
Feb 21, 2015 | Zhone Computers & Internet
How do i enable upnp on ZNID24xx-Router ?
Get the manual from here
http://setuprouter.com/router/zhone/znid-gpon-2426-uk/manual-1298.pdf
There is no UPNP on this router. The best you can do is put it into bridge mode and add a router on the LAN to do port forwarding as it is not possible on the OTN described here.
Dec 20, 2014 | Computers & Internet
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
ROUTER NOT WORKING WITH USB, BUT IS WORKING WITH LAN CABLE.. CAN SOMEONE PLEASE PROVIDE THE DRIVERS FOR MY LAPTOP TO WORK WITH IT VIA USB THANKS
You do not want to use USB with your router. Plug in the Ethernet cable and you should be okay. LAN cable is the best solution.
Aug 15, 2010 | Zhone 6211-I3-200 Router
Can i connect a wrt54g wireless router to a zhone? to get wireless access on my laptop and wired connection to my computer?
s u can connect as u wish. connect a utp cable lan port of ur wireless router to ur pc. assign ip for ur pc with router's ip as gateway address. similarly search for wireless networks from ur laptop. u will find ur wireless router to in that range. click on it connect to the network. the ip gets automatically assigned for the laptop. Thats it u are done!!!
Jul 21, 2010 | Zhone (6218-I2-200) Router
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Jul 16, 2010 | Zhone (6218-I2-200) Router
Access my lan from the WAN
I assume you want to log into your pc from another pc outside your lan. To do this you need to forward port 3389 to your pc.
  1. Make sure your pc (the one you want to connect to) has a static ip address. Also, it should have a password on the windows account you use.
  2. In the router, forward port 3389 (tcp) to the ip address of the pc.
  3. If you do this correctly, you can go to any pc outside your lan, and use remote desktop connection to connect. When you start the remote desktop connection, put in the wan ip address of your lan. If you did the port forwarding correctly, you will be asked for a user name and password. Put in the username and password for your user account on the lan pc and voila! - you are logged into your lan pc remotely.
Let me know if this works, or if you need some more help.
Aug 08, 2009 | Zhone 6211-I3-200 Router
Problem setting up zhone router
I reseted the router and started over.
Feb 05, 2009 | Zhone Router
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Computers & Internet Logo
16 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
