Question about RCA D61W20 61" Rear Projection Television
Buy d61w20 repair kit
Capacitors
I have a RCA d61w20 that on first turning it on it takes for ever the power like blinks then after about 10-20 min it turns on and is fine all day as long as you don't turn it off
thats usually caused by failed CP150 CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com which also contains the repair instructions and replacement capacitors.
Mar 07, 2012 | RCA Televison & Video
I've replaced cp150 cp120 cp114 capacitors and now it turns on for about 2 - 3 min and then turns off what else could it be? rca d61w20
It could be the flyback transformer or several other items all on the deflection board. Were any of the caps you replaced domed up on top?
Jun 18, 2011 | RCA D61W20 61" Rear Projection Television
My rca d61w20 rear projection television will not turn on. green light indicator will come on for 5 sec. then go out. any ideas?
Replace the CP150, CP120 and CP114 capacitors you can get the RCA repair kit by that same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Feb 17, 2011 | RCA D61W20 61" Rear Projection Television
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
My tv will not come on it just flashs three times then goes off but if i hold the power button down it flashs code no 19
Replace cp150, CP120 and CP114 capacitors. You can get the repair kit by that same name at www.tvrepairworld.com and the kit also has the CD with detailed instructions.
Jan 09, 2010 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61 in. Rear Projection Television blinks three times when trying to turn it on then quits blinking and the television will never come on. What's the problem?
Most likely its the CP150, CP120 and CP114 capacitors. You can get the repair kit with that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Jan 08, 2010 | RCA D61W20 61" Rear Projection Television
The Tv we have is the RCA D61W20 and it wont do anything it will not power on. What should we do?
Its most likely the failed capacitors CP150, CP120 and CP114. You can get the repair kit with that same name at www.tvrepairworld.com the kit also contains the CD with repair instructions.
Jan 07, 2010 | RCA D61W20 61" Rear Projection Television
RCA D61W20 Projection TV
On the Deflection Board CK 3 capacitors cp150 2200uf 16v cp114 cp120 220uf 35v If cp 150 is puffed up top then it is bad so replace all 3 capacitors. Resolder all pinns on FBT too. and make sure second ribbon connector is in good.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Where can I buy two capacitors for my Mitsubishi WD-52525 52 in?
Thats the best place to order them from, as they have the correct replacement cpacitors which are the high temp orgional capacitors. They should have which ever ones you need.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
