Samsung ML4512ND: ML-4512ND Laser Printer Logo
A
Anonymous Posted on Dec 31, 2013
Samsung error M1-4111
Paper tray does not lift
3 Related Answers
Anonymous
  • 406 Answers
  • Posted on Mar 16, 2010
SOURCE: samsung scx-6345 21.006 tray lift error
Try changing the SMPS.
puertobori
  • 7733 Answers
  • Posted on Oct 27, 2010
SOURCE: using A4, paper is not
Try this LINK
CreativeTECH
Creative Tech
  • 1719 Answers
  • Posted on Nov 10, 2010
SOURCE: Get paper jam in paper
Pickup roller may not be working properly and it may require cleaning using dry lint-free cloth or if needed glass cleaner or mild detergent can be used. Use damp cloth and BE CAREFUL NOT TO SPILL ANY LIQUID IN SIDE THE PRINTER. EXCESSIVE PRESSURE AND CLEANING MAY DAMAGE RUBBER PADS AND ROLLERS.
Do check for any damages to the paper pickup roller. Please make sure that the paper path is clear and there is no dust or paper pieces stuck inside the printer.
Hope this Helps!
CreativeTECH
How to setting E02-02 code panasonic photocopier machine
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
My minolta bizhub c6501 has a trouble code of c0203. How do I fix it?
Description
Intermittent C-0201 (C0201), C-0202 (C0202) and C-0203 (C0203)paper lift error codes.
Solution
PROBABLE CAUSES:
1.The trail edge paper guide (p/n A03U R756 00) may not be pressed against the paper. This will allow the paper to fall backwards and induce the error code.
Instruct the end user to check the position of the trail edge paper guide whenever paper is loaded into the paper tray.
2. Coupling for the tray lift for Tray 1, Tray 2 or Tray 3 is obstructed or out of alignment causing the tray to not lift.
Inspect the coupler in the back of the machine for paper preventing the pin from seating in the coupler. Check alignment when tray is inserted. If out of
alignment try to adjust the drive to properly align.
1helpful
I'm getting an error code 60.02 on a HP 4014N printer. How do I troubleshoot the problem
An error has occurred while the product was attempting to lift the tray designated by XX. Pull out tray 2 and remove most of the paper. Push the tray into the printer and listen for the lift motor and watch the paper level tab in the front of the tray. If you don't hear the motor and the tab doesn't move, it's possible the printer has a bad lift motor. Remove all the tray 2 paper and look for any paper scraps in the tray. Reinsert the paper and listen for the motor and watch the tab. If it works, great, if not call a tech.
1helpful
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
5helpful
2answers
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
1helpful
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
60.40 tray lifting error
lifting error should be describing the part of the paper tray or paper feeding mechanism that physically lifts the paper up in the tray to be fed into the print engine.
does this happen from all trays? describe your jamming if any.
1helpful
2answers
Shows error code CO900
A C0900 is a paper tray problem. Try to check your paper trays and make sure that there is not any paper in the paper tray wrong or doubled up in the paper tray, it may hender the paper tray from liftting in time.
5helpful
3answers
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
