Question about JVC AV-36D303 36" TV
Jvc f21mx5 red ligths only - JVC AV-36D303 36" TV
    Top Expert:
  • JVC Master
  • 74,377 Answers
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Dec 31, 2013
My truck stop running with out any red ligth no chech engine ligth no codes at allt it is like its sucking air intead of diesel
Check fuel level in tank, check filter housing is not sucking air, check all fuel lines for leaks...
Check operation of lift pump...
Feb 12, 2016 | Cars & Trucks
DL 160 red ligth alarm hard disc
You could try re-seating the hard drive to see if comes back. Note most configurations on this is set to RAID 1 or 5. Double check before removing drive.
The drive will need to be replaced if the red light comes back (after a few days).
Jan 31, 2013 | HP Computers & Internet
The vertical ic of my jvc tv model no. av f21mx5 are always burn even i replace a new one
Just check the supply voltage input to the vertical IC. If it is more than normal, this type of fault can occur. Just compare this voltage . The TV schematic will help you to find this detail. Check whether the IC is firmly screwed on to its metal heat sink.
Jul 03, 2012 | JVC AV-20020 20" TV
Green ligth comes on and then gose off, proceed by red ligth flashing.
Hi:
If you count the number of times the red light blinks before pausing and starts to cycle over again. This is the error code the unit is producing. Also if its been a while since you replaced the lamp then it may be time for a new one. Check the lamp housing and pull out the lamp it may be shattered. You can find the lamp area and installing instructions using you onwers manual.
Nov 10, 2010 | Sony KDS-50A2000 50" HDTV
My car has a small red ligth in side panel by the estering well that is flashing and make a sownd like a emergenci ligths on
probably part of a antitheft system,talk to previous owner or disable it.
TIM...................
Oct 21, 2010 | 1993 Dodge Intrepid
Warning red ligth
you can have the vehicle check for code with a hand held device then you will know what sensor cause the light to come on.
after you make the necessary fix you can erase the code then the light will turn off
Mar 03, 2010 | Mitsubishi Cars & Trucks
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Flashing ligth
Usually means the battery is not seated correctly or is not charging.
Jan 18, 2009 | Dell Inspiron 5100 Laptop
Red crt tube
IT IS PROBABLY TIME TO CHANGE IT OR THE LIGTH DIFFUSER THAT SENDS THE LIGTH TO THE TUBES OR LAMPS IS MALFUNCTIONING
Oct 01, 2008 | Philips 60PP9202 60" Rear Projection...
JVC AV-36D303 36" TV Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
