Question about Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses
Camera not turning on
Took a few photos with camera now wont turn on at all had charged batterie before use
    Top Expert:
  • Olympus Master
  • 6,702 Answers
Remove the battery and charge it again. If you only can make just a few shots with the battery and it stops again, think of buying a new battery. Special when you have not used the camera for a long time, the second and third charge can be better. If not the battery is on its end of life.
Posted on Dec 31, 2013
SOURCE: Wont turn on
your all in trouble.. im on my third one..a pro surfer/shaper... you must wast it completly with fresh water immediatly after leaving the sea.. the chrome corrodes within hourd and allows the seals to leak. also sand etc gets stuck in the lense door...
Posted on May 25, 2008
iwctoys
  • 126 Answers
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Posted on Jul 02, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Posted on Feb 15, 2010
SOURCE: My Olympus underwater camera wont turn on, i took
hmm well looks like you might have a problem... if you have it still under warranty take it back your probaly out of solutions
Posted on Mar 01, 2010
  • 125 Answers
SOURCE: the charger red light kept
Welcome to FixYa.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
Thank you for using FixYa.
Posted on Apr 11, 2011
Won't take pictures.
Put a clean sd card in, take lens cap off and turn on
it should work if its not broken.
Aug 08, 2014 | Nikon Coolpix 5700 Digital Camera
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
Wont go to picture taking screen or playback menu
A lot of cameras seem to be having this issue (including myself). Eventually it got to a point where the camera doesn't even turn on properly anymore. Better take it back for repair, STAT before it ends up like mine :(
Jun 29, 2010 | Fuji FinePix J10 Digital Camera
Flickering and loss of colour
Problem now solved. I switched the camera on and off a few times and took several test photos. After a few minutes the problem resolved itself. I suspect the cause was condensation, but cannot be sure.
Jan 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
It wont turn on i tried charging the battery to see if it was dead but it wasnt the battery it wont turn on!
Are you sure it is dead or is it simply that liveview is not showing? A friend of mine thought hers was dead the other week but liveview was turned off. Try taking a few photos and see if it actually takes them?
Jun 11, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
CAMERA WON'T TURN ON
1) remove the battery and place it in the freezer. for an hour or 3.
2) charge the battery (let the battery unthaw first, don't charge the battery if it is frozen it may explode.)
-if this doesn't work you may need another battery.
Apr 08, 2009 | Nikon Coolpix 8700 Digital Camera
XT not turning on
I was taking pics with my rebel EOS and it turned off. I charged and changed the battery but wont come on
Sep 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Olympus E-520 Digital Camera with 14-42mm and 40-150mm lenses Logo
54 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
