Question about Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive
Western digital hard driver not recognized need driver
SOURCE: External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
Posted on Jun 08, 2008
brilliindian
  • 8 Answers
SOURCE: My computer does not recognize
if u are using a external hard disk case with the normal hard disk
try connecting your hard disk with a new casing.
if it is made as a external hard disk change the cable .
because after a few time usage the cable will not be quite good as new.
After inserting the usb cable in your pc if it shows any warning
information, or any message just give me that too for exact solution
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: MY 1TB Western DIgital Ext Hard Drive is not recognized
Go to add new hardware wizard. This may not come with a disk if you do have a disk it will ask you to put disk in. If you do not find it there go to the HCL directory of the western digital website for installation directions.
Posted on Jun 04, 2009
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
Posted on Jun 07, 2009
mbase213
  • 728 Answers
SOURCE: Need driver for Western Digital Scorpio
Hi raider4123,
The Western Digital Scorpio (WD2500BEVS) doesn't come with a driver, but I have an idea that perhaps you may have a pin setting wrong, making the drive not recongizeable. Here is the information on setting the pin on the back'
If that doesn't seem to solve the problem, then I'd run the WD Lifeguard software, that will detect any problems and correct them for you. You can find that software HERE.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Posted on Sep 15, 2009
Western Digital book drive is not recognized by pc. Information cannot be accessed
Try having your PC scan for devices again to see if it work then. If not, go to the Western Digital website to find a driver for it. Hope this helps! :-)
Jul 20, 2014 | Western Digital Computers & Internet
Just bought a new cpu, put it together and purchased the western digital 160 gb sata II model number WD1600AAJS. i am installing windows 7 on it, or attempting and it won't recognize the drive. it says it...
The drivers are not needed, West. Digital is right. Your problem is that the hard disk is not recognized by the motherboard (not the cpu). Since you didn't mentioned anything about motherboard's brand / model, I have to tell you that you have to get into the bios settings and get yout hard disk recognized by the bios. I assume that the connections are right.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Western Digital Caviar SE WD1600AAJS 160...
My computer wont recognize the drive or allow me to reformat my passport.
Try downloading the device driver from western digital site for your respective OS. And try formatting it with the western digital inbuilt software, which works great.
Jun 30, 2010 | Western Digital My Passport Essential...
MacBookpPro osx10.4.11 doesn't recognize new WD passport
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
//javaftper
Apr 02, 2010 | Western Digital Passport WDXML800UE...
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Software for the western digital elite hdd when using vista 64bit
What kind of software are you looking for? This should be automatically recognized by Vista as an external storage device. If it is not recognized and you cannot see/use the device; you need a driver to allow vista to talk with your USB device. Are you looking for backup software? Please clarify.
Jun 06, 2009 | Western Digital External USB 2.0 80 GB...
My computer recognizes the western digital but i cant view my files.
just update the chipset drivers of ur system form the vendors site,,, tat ll solve the issue...
Jun 02, 2009 | Western Digital 250GB MyBook External USB...
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Western Digital Hard Drive not detected by my computer
More information may be needed, however...
I'm guessing you have a SATA Western Digital Hard Drive. You will have to install the SATA drivers before it will recognize it.
If that's not the issue, please let me know what kind of hard drive you have and what computer you are installing it into.
Jan 11, 2009 | Computers & Internet
Western Digital My Passport Essential SE 1TB External USB 20 Portable Black 1 TB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
